D315 engine spec question
chrismill
Send a private message to chrismill
Can anyone tell me what the max clearance between rod bearing and journal is?
I saw .013 but not sure if that's right-
Also is the rod bearing part# the same for serial#7u 18433 as 27565?
I only have a later(27565&up) parts catalog.
-thank you
Tue, Sep 6, 2016 10:25 PM
my parts book 7u1---7u27569 gives the bearing as 4F2883
Wed, Sep 7, 2016 6:30 AM
Thank you received: 48
Reply to dpendzic:
Maximum permissible clearance is 0.013".
Wed, Sep 7, 2016 10:33 PM
