D315 connecting Rod question.
Showing 1 to 7 of 7 results
chrismill
Send a private message to chrismill
I have a d47u that had a knock. Took of the inspection plates and found #2 connecting Rod loose and clanking around. Took the bearing cap off, the bearing had totally disappeared into flakes/ chunks. At looking at the cap, the pin/ stud that holds the bearing shell in place is ground flat. My question is can that pin be replaced or do I have to get a new connecting Rod? The journal on the cranckshaft looks and feels surprisingly smooth but need to gauge it. The way that pin is ground flush with the cap I'm guessing I may need a new connecting Rod to gauge it right. And I'm guessing that I won't be able to replace the Rod through the side cover- Friend of mine who has much more experience than myself when it comes to rebuilding engines says I should look for a used engine. Not sure if I should-
Wed, Oct 19, 2016 7:19 PM
jmvmopar
If the crankshaft is grooved then your friend is right.
If the bearing spun in the rod. Then you need to replace the connecting rod.
Wed, Oct 19, 2016 9:54 PM
willitrun
Send a private message to willitrun
Reply to jmvmopar:
chances are it just pounded the hollow pin up in the rod. i'm thinking you're committed to pulling the head and removing the connecting rod.
Thu, Oct 20, 2016 12:45 AM
Reply to willitrun:
You may be able to pull the piston down and out through the inspection port.
It will be tricky to squeeze the rings to slip it back in but I know it can be done on a D2!
Thu, Oct 20, 2016 1:11 AM
gemdozer
Reply to drujinin:
I have some used d315 connecting rods
Thu, Oct 20, 2016 3:40 AM
chrismill
Reply to gemdozer:
Oh great I think I'm interested in one of those then , thank you. There are no grooves worn into the crank as far as I can tell with my fingernail. But trying to pull the piston down and out through the side cover may be pretty tight- and yeah getting it back in- it was hard enough to get the rear cotter pin out by "feeling" for it with a pair of needle nose on the backside of the bearing cap haha..
Thu, Oct 20, 2016 3:47 AM
Andrew
Reply to chrismill:
You will at the least be in for a crank grind.
Thu, Oct 20, 2016 6:14 PM
Jim Davis
Send a private message to Jim Davis
Reply to Andrew:
What's the status of your rod issue? I have a similar issue with my D2. Think I can get a way with replacing the bearing dowels and bearings--through the inspection plate.
Interested in your progress.
Jim
Tue, Nov 15, 2016 10:21 AM
