D311H engine compatability?
Showing 1 to 10 of 14 results
squiggle73j
Send a private message to squiggle73j
Question from left field - will the later model D311H engine, (aluminium rocker cover) swap into a Cat 212 grader with the older model D311 (same as 4U-5U D2 tractor) I am trying to get my old 212 grader going and parts are pretty costly for the old engine
Thu, Mar 21, 2019 9:14 AM
Nothing on a D311H is compatible with the D311. Completely different engine.
Thu, Mar 21, 2019 10:00 PM
STEPHEN
Compatable might not be what he is after. Just has anyone swapped complete engines. It would be much cheaper to use the older 311, I think there were more made, more used parts available. Do not know what the new or used parts outlook is for the later industrial 311H
Thu, Mar 21, 2019 11:23 PM
Rd6 plower
Send a private message to Rd6 plower
Reply to STEPHEN:
So did the D320 replace 311h? What where bore n stroke on them? Never seen one and did they come in any equipment like 933
Fri, Mar 22, 2019 12:15 AM
STEPHEN
Reply to Rd6 plower:
I have seen only one, on a gen set
Fri, Mar 22, 2019 12:33 AM
The D311h is a 4" bore x 5" stroke NA engine. The D320 is the turbocharged version.
I have a D320 in a 922b series 59a wheel loader, so I could do some measuring if it would help. Unfortunately I don't have an old D311 to compare to.
I doubt a 212 grader is a good candidate for a swap because (if I remember correctly) the oil pan bolts down to the rear axle and the radiator support hangs on the front(rear in the grader) of the engine. Just more dimensions to match up!
Fri, Mar 22, 2019 1:10 AM
Thank you received: 78
What parts do you need for the original D311?
Fri, Mar 22, 2019 1:27 AM
D311H's were used in the 933 42A's up to s/n 42A5917 and then used the D320T's from s/n 42A5918 to end of production at 42A9202. Probably more common in Industrial applications and some marine but I would consider them to be an orphan engine.
Fri, Mar 22, 2019 3:28 AM
squiggle73j
Thanks for the interest, the D311 has been submerged in a flood, cylinder liners are unserviceable but the rest of the engine has been preserved, to get it running, piston liner kits, overhaul head and crank bearings to suit. Parts for these are difficult to find in Australia and very expensive through Cat, some are available only ex-America at present. Open to suggestions, but I agree its not feasible ( I forgot about the sump)
Fri, Mar 22, 2019 4:02 AM
Mike Meyer
Reply to squiggle73j:
Don't be afraid to buy parts in the USA, I've found folks like Florin Tractor brilliant to work with, there is a guy in Melbourne who consolidates freight in California for cheaper shipping options than the US Post, I bought new D2 liners from Cat here in Oz 6 or 7 years ago but see they are currently not available here in Oz, but plenty available in the USA, most likely aftermarket, you could re-sleeve those liners of yours though they will be rock hard, probably diamond hard, sleeves are around $50 or $60 in Melbourne.
Do you use the Machinery Trader website to find parts, I see Expressway Spare and Smiths are showing crank bearings, plus many sources in the USA, I assume if you are like most us Catheads you are looking for the cheaper options first, like a complete donor engine, I was told years ago the D2 engine off worn out dozers was popular on paddle boats on the Murray.
Have you tried Tilly's up in Toowoomba, Paul Moore can also be a good guy to talk to, there were a lot of D2's made, and many are still on cane farms in banana bending land.
Mike
Fri, Mar 22, 2019 4:45 AM
squiggle73j
Reply to Mike Meyer:
Mike
Thanks Mike, onto it and making further enquiry, Hope to catch up one day,
Cheers John
Fri, Mar 22, 2019 6:28 AM
