D311 GenSet Question
jtpasto
Send a private message to jtpasto
What is the difference between a D311 diesel engine & electric set serial number series 4v5001 and a D311 diesel engine & electric set serial number series 7s5001?
Sat, Aug 15, 2009 2:31 AM
SJ
Send a private message to SJ
The Cat SNID book lists the 7S as just an industrial engine (not a gen. set) and the 4V is listed as an electric gen. set. There would be changes probably in the governor setup and settings in them as I have seen it with other Cat engines used as gen. sets and industrial engines and also there could be a control or two on the gen. sets and not on the ind. ones but ind. sets do have some controls on them.
Sat, Aug 15, 2009 2:55 AM
jtpasto
Reply to SJ:
I got confused looking at the Caterpillar Legendary Service Literature because it shows S/N 4v5001 and 7s5001 under both diesel engine & electric set and again under just engine.
Sat, Aug 15, 2009 3:22 AM
| Kingaroy, Queensland
