D311 cylinder parts help
grayrat
Send a private message to grayrat
I have a 212 grader SN 9T2490 with D311 in need of pistons, rings, sleeves and top and bottom rubber and copper seals. I see a foot note about 5H7269 piston and liner replacement group, not clear if rings are part of this kit. I don't need new rods just bearing and I don't see any individual PN's
Rings show in sets for 2 pistons 5F331 so would need 2 sets of 5F331? Any input and source recommendations would be helpful.
Fri, May 8, 2015 10:05 AM
Start with a call to Florin Tractor.
Fri, May 8, 2015 12:18 PM
Uncle Rich
Send a private message to Uncle Rich
What's wrong with you Pistons? Did you measure them and the bores? You might want to price those parts, if you can even find some before making the decision that they need to be replaced. A good hone, bead blast Pistons and knew rings goes a long way.
Sat, May 9, 2015 11:12 AM
