D311 accessory drive.
Showing 1 to 10 of 12 results
mog5858
 Does anyone know if there's an HP rating on the accessory drive on the front of the D311? could one take off a generator and replace it with a hydraulic pump?   would like to have live hydraulics and don't want a pump hanging off the front.  thinking 5-8 GPM range probably would be a gear pump as they are cheap and simple.
Thu, Jul 13, 2023 5:58 AM
Thank you received: 287
I don't know the HP rating, but I have a U series D2 here with hydraulics adapted to it in place of the generator. Works just fine. I have/had a J series as well set up similar. JM
Thu, Jul 13, 2023 7:18 AM
Busso20
Thank you received: 31
JM would you be able to show a picture of the set up? sounds interesting and what do you power with it? my 3J has rear PTO with sprocket and chain to drive pump, never seen engine drive train doing the work.
Cheers Jamie
Thu, Jul 13, 2023 7:33 AM
Reply to Busso20:
Cheers Jamie
I can take a photo of it when I can remember which building I parked it in! I will gladly go look for it today, and get out of the heat.
The 5U came to me with it already installed; not the prettiest set up, but it works well. The tractor has been used to pull hydraulic controlled disks and orchard levelers.
The previous owner said it was "field engineered" by some old tractor hand. I will reply later today. JM
Thu, Jul 13, 2023 8:53 PM
Okay, it was inside the diesel dungeon here.
Fri, Jul 14, 2023 2:17 AM
mog5858
thanks JM that's what I had in my head doesn't look too bad at all. so I guess that answer my question that it will work. somedays I wonder as there's a lot of ideas floating around up there.
Fri, Jul 14, 2023 5:49 AM
D4Jim
Reply to mog5858:
Gosh Gee I thought my eyes had gone out of "kilter" seeing all the yellow in that one photo. Thanks for posting.
Cats Forever
Sun, Jul 16, 2023 2:01 AM
Busso20
Reply to D4Jim:
Nice arrangement for the pump and looks very good, at least live power at hand, nice to see all the machines in under cover, a life time of history and stories there
Sun, Jul 16, 2023 8:58 AM
HUDCO
Send a private message to HUDCO
Reply to Busso20:
juiceman what does that allis hd6 compare to caterpillar modal wise ?
Mon, Jul 17, 2023 2:53 AM
wimmera farmer
Thank you received: 10
Reply to HUDCO:
Please put a relief valve in the system. I kow of a D318(D8U) that was set up very neatly untill they deadheaded the pump . That wrecked some timing gears real quick.
cheers WF
Mon, Jul 17, 2023 4:28 AM
Thank you received: 62
Reply to wimmera farmer:
cheers WF
A D4 D model would be very similar horsepower wise to a HD 6 of the same time frame . Cat , IH, and AC never let the other companies get very far a head in the HP game.
Mon, Jul 17, 2023 5:08 AM
