D3 B Water in oil
D3 B Water in oil
Showing 1 to 10 of 10 results
ali sleiman
Send a private message to ali sleiman
Hello All
I can use some insight as why my D3B got water in engine oil
Cat service man think it condensation. , The machine was not used for a while . I had to change my knee
Got it running again now have this to deal with. Drained the oil and took the filter out. Filled the radiator overnight it did not go down
I would like to flush the engine , what is the best way
Sun, Sep 8, 2019 8:31 PM
I suspect the oil cooler if its not condensation--I flush my machines engine and tranny, by just changing the oil
Mon, Sep 9, 2019 2:10 AM
Reply to dpendzic:
With no liners and belt drive water pump there aren't many sources for water in oil. Do you see any bubbles in the radiator when running? Oil cooler will put oil in water not usually the other way round. Head gasket and/or cracks would be most likely source. Do a couple of oil changes and monitor levels, could just be condensation, doesn't take much to foul the oil.
Mon, Sep 9, 2019 2:40 AM
ali sleiman
Hi Old Magnet
Good to hear from , I was surprised when that happened , but having been out commission for a while should expected it.
I wanted to confirm from the expert before tearing into major repair . I got the oil drained and will put new filter and see what happens
Thank you
Mon, Sep 9, 2019 4:45 AM
Reply to ali sleiman:
Hi Old Magnet
Thank you
There are also some core cup plugs in the head (under the valve cover) that can rot out and leak. I'd check those first if your still missing coolant.
Mon, Sep 9, 2019 6:45 AM
ali sleiman
Well I don t know if this mean anything , as I stated earlier that I filled the radiator with water and now for about 3 days water level did not go down at all.
Now the engine has been drained from oil , I was thinking that some water level will go down due to gravity if there any leaks.
Tue, Sep 10, 2019 12:14 AM
While it’s true a leaky oil cooler almost always puts oil into radiator coolant, WHEN the tractor has been sitting up, it can easily fill oil pan with coolant. Then the leak is discovered and more major engine repairs undertaken and completed before the engine is ever run. THEN THE OIL GETS PUSHED OUT THE LEAK INTO THE COOLANT.
Not good😁
Wed, Sep 11, 2019 1:38 AM
ali sleiman
Not good😁
Hey Magnet
good comment CC Jersey, we Alabama boys need to stick together
I am working on finding the leak . in the meantime rebuilding other things such hydraulic cylinders. have 2 leaking .
would like to know if the front seal crankshaft can be changed with out taking the front hood and radiator. At least the cat shop manual show that it can be changed. of course they have special tooling.
Wed, Sep 11, 2019 7:54 AM
ali sleiman
Hey Magnet
I spend all week draining all fluid from Engine and transmission and changed the oil filter, cleaned the screen etc.
Put new oil. Started the engine and let warm up in 95 deg Alabama fall weather. Good news the engine is fine and water in the oil.😖mile:
Rebuild all hydraulic cylinder, they needed. Also made sure all drain plugs had their seals O ring, which they leaked..
Also opened the steering clutches compartment to make sure no oil leak or water and also loosened the brake pads to make they are now stuck. .
so far I can drive it but can not steer. I have not put it under a load yet
Now have to go thru the steering clutches adjustment to make sure they are releasing .
Any suggestion
Wed, Sep 18, 2019 5:39 PM
Any suggestion
are they dry steering clutches or wet clutches as mine has?
Thu, Sep 19, 2019 4:49 AM
ali sleiman
Reply to dpendzic:
Hi Dpendzic has dry clutch
Thu, Sep 19, 2019 8:27 AM
