D2N Shift Lever
D2N Shift Lever
Showing 1 to 9 of 9 results
n7gxz
Send a private message to n7gxz
I'm mounting a D2N winch on my D2 and I have a small problem. The winch came off a pre 4U6373/5U13237 tractor, mine is 5U13247, so the shift control is not the correct on for my tractor. Does anyone have a D2N mounted on a tractor with a serial number of 4U6373/5U13237 and up that could take some picture of the shift control lever and mounting?
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Sun, Mar 22, 2009 10:09 PM
Sun, Mar 22, 2009 10:55 PM
n7gxz
May find your answer here:
http://www.alliedsystems.com/pdf/Winch/Manuals/599228W.pdf
[quote="Old Magnet"]May find your answer here:
http://www.alliedsystems.com/pdf/Winch/Manuals/599228W.pdf[/quote]
I've already download the manual. It does not give a very detailed view of the shift lever.
Kevin
Mon, Mar 23, 2009 12:20 AM
josh
Thank you received: 14
Reply to n7gxz:
Kevin
Is this what you are looking for ?
Mon, Mar 23, 2009 2:59 AM
n7gxz
Reply to josh:
Yes it is Josh. Could you take some measuments for me or some pictures with a ruler in the pictures?
Also do you have the seat raisers? What size are they? In the manual they look like the are channel iron, is that correct? I was thinking of using 2x4 box steel.
Thanks, Kevin.
Mon, Mar 23, 2009 3:22 AM
josh
Reply to n7gxz:
Thanks, Kevin.
Kevin,
The horizontal overall length of the shift lever is 8-1/2", the shift lever indexing bracket is 6-3/8". I do not have the origional seat risers, I figured them to be 1-1/2" x 3" channel, I think 2x4 box might be a little too big.
Mon, Mar 23, 2009 9:05 AM
n7gxz
Reply to josh:
Kevin,
Thnaks Josh. The picture of the brake lever is nice to have as well as the earlier on is straight and I have to make an offset one of thoes as well.
On the indexing bracket on the curved part how wide and high is it, make since? It looks to be 1/4" thick.
Kevin
Mon, Mar 23, 2009 10:01 AM
ol Grump
Reply to n7gxz:
Kevin
The seat risers on mine, D4 7U 18586 are 1" thick vertically. The seat tank clears everything by about 1/2 - 3/4" underneath. As I recall, it looks like one brace under the seat was trimmed slightly to clear the rod from the control lever to the winch.
Mon, Mar 23, 2009 9:18 PM
josh
Reply to ol Grump:
The indexing bracket, including the plate it is mounted on, is 5" high, it's 4-1/8" wide, the radius of the curve is 3", and it is made out of 1/4" stock.
Tue, Mar 24, 2009 10:06 AM
n7gxz
Reply to josh:
Thanks Josh I had come out pretty close to that. I had come up with 2.75" radius. This will be interesting to build. I've been trying to think if I can find some pipe with the needed curve or to try and bend a piece of flat plate.
Kevin
Wed, Mar 25, 2009 10:11 AM
