D25U searching for chambers and valve's
AndreHaak
Send a private message to AndreHaak
Hello,
We have a D25U serialnumber 17520 with an direct elctric starting unit.
There are glowing plugs through the retainer into the chaimber. Can someone tell me if there are new chaimbers with retainers and glow plugs and injectors available for this machine. We also need new valves for the machine, are these valves also still available?
Sun, Feb 26, 2012 3:50 AM
Mike Walsh
You will find a lot if info on the site about direct electric start D2 precups. The solution is to fabricate them. Here is a thread that will get you started.
http://www.acmoc.org/bb/archive/index.php/t-7668.html
The D4/D6 precups are cheap and available aftermarket for about $30 US.
Sun, Feb 26, 2012 8:02 AM
Reply to Mike Walsh:
Get the one piece (no retainer required) 1S1970 glow plug chambers and turn the thread down from 1-1/8" x 12 tpi to 1" x 12 tpi to fit the D2. Original D2 chambers are no longer available.
Be sure to use the 6F8061 injector retaining nut as original.
Try Cat, they should have your valves.
Sun, Feb 26, 2012 8:47 AM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
