D25U pony carb question.
bpusmc
Send a private message to bpusmc
I’m overhauling my TU4C carb which has never idled properly and always ran very rich. Pictured are top and bottom views of the metering well I removed and the replacement I ordered. The opening in the one I removed measures .15 and the one I received as the correct one for my model carb measures .07  I double checked with the supplier and was told the .07 is correct. Squatch Senior’s video seems to show the larger (.15) opening. Anyone have any insight as to which one is correct? [attachment=71191]A7B70B28-0853-4DDE-BCCE-5A0F85A229E4.jpeg[/attachment] [attachment=71190]1BC0D7FE-D45D-4E98-BBD1-403E622F4DEE.jpeg[/attachment]
Tue, Feb 21, 2023 9:47 PM
Shaban1983
Send a private message to Shaban1983
I have seen about 4x TU4C carburetors, all 4 have the opening like on the left.
There should be a small number stamped on it somewhere, this number is its throughput and it should be the same for both
Fri, Feb 24, 2023 7:33 AM
| Kingaroy, Queensland
