D25U Fuel headaches
D25U Fuel headaches
sleeve62
Send a private message to sleeve62
After sitting idle for A few days the fuel system needs bleeding again. While allowing the diesel to tun over with the compression release in the start position fuel issues from the first filter housing bleeder , but not from the vent post filters. Fuel issues from the " bleeder " lines out onto the ground. Replace relief valve and spring , cleaned seating surface but the problem persists. " Tinkering" i.e. bleeding, filling fuel tank completely etc. and she will finally start and show normal fuel pressure . Gremlins ? Any help will be greatly appreciated. Sleeve
Mon, Oct 3, 2011 5:43 AM
zootownjeepguy
I was fighting the same problem with my CDU, right up until that tired old pony motor threw a rod. I'll keep an eye on this thread for sure!
Rich Salvaggio
D2 5U9917
Mon, Oct 3, 2011 5:59 AM
Reply to zootownjeepguy:
Notice any fuel mixing with the crankcase oil?
Mon, Oct 3, 2011 6:04 AM
| Kingaroy, Queensland
