D2 winch gasket
D2 winch gasket
Showing 1 to 6 of 6 results
15sp4250
Send a private message to 15sp4250
I am getting ready to install a D2N winch but don't have a parts book for it. Does anyone know if the big gasket is available from cat between the winch and the transmission case? If so could i please have a part number. If not looks like i will be making one.
Thanks for any help,
Sam
Mon, Mar 4, 2013 7:38 PM
josh
Thank you received: 14
The only new parts that are available for those winches are seals and bearings, you get to make your gaskets.
Mon, Mar 4, 2013 11:50 PM
n7gxz
Send a private message to n7gxz
Reply to josh:
I used RTV when I mounted mine.
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Tue, Mar 5, 2013 6:35 AM
Gregness
Reply to n7gxz:
Kevin
[quote="n7gxz"]I used RTV when I mounted mine.
Kevin[/quote]
You are lucky to have one to mount up!
G
Tue, Mar 5, 2013 8:12 AM
STEPHEN
Reply to Gregness:
Kevin[/quote]
G
I would guess that the gasket would have a Hyster part number
Tue, Mar 5, 2013 8:54 AM
15sp4250
Reply to STEPHEN:
Thanks for the help looks like ill cut some gaskets and add a little help with rtv.
Tue, Mar 5, 2013 8:51 PM
mog5858
Reply to 15sp4250:
i wish i had your problem as i too would love a winch of my d2. i got a logging arch ready to go to work but no winch. well good luck take some pic of doing for us that way we can see how it's done.
Wed, Mar 6, 2013 1:14 AM
