D2 water pump rebuild
Showing 1 to 7 of 7 results
D2Fred
Send a private message to D2Fred
I am rebuilding the water pump on my D2. 4U 6123 d311 engine. I replaced the bearings and seals in the front and installed a new ceramic type seal for the coolant. I got a new impeller for it because I broke it when I was pulling it off the shaft. The original set up has the seal riding on the impeller. The seal I have now has a polished washer and rubber sleeve that would go in front of the impeller. Question is, is there enough room to install the washer or should the seal run on the impeller like original?
Fri, Dec 10, 2021 7:48 AM
The new impeller should have a ceramic washer on it which the the new seal should ride on. Also make sure there is a relief valve 6U1989 [4B4550 former#] in the pump housing, NOT two grease fittings.
Fri, Dec 10, 2021 9:04 AM
d4angelo
Thank you received: 7
Just an F.Y.I, when I rebuilt the one on my D2 5U I tapped the fan blade back on the shaft using an oversize socket and a hammer. Not a good choice because I ruined the new seal. So I just worked it back on the shaft by putting the proper size socket and ratchet on it and turned it. I was so proud of myself....... until I put coolant back in the radiator and watched it hit the ground. Just trying to save somebody some time and $
Sat, Dec 11, 2021 5:17 AM
Thank you received: 288
Reply to d4angelo:
It takes a real person to admit they boo booed. Glad you chimed in, and I am glad you shared, as it is better to learn from others most of the time!
Yes, hopefully others can learn from your unfortunate incident. JM
Sat, Dec 11, 2021 6:49 AM
Jack
NOT two grease fittings? Mine came with two grease fittings installed and is still that way. I had wondered about that. Which hole is supposed to be used for a grease fitting and which is supposed to be open? (D2 5U engine made up of pieces from salvage yard.)
Mon, Dec 13, 2021 10:26 PM
josh
Thank you received: 14
The relief valve looks like a grease fitting that is short, or has been cut or broken off, and is commonly mistakenly replaced with a grease fitting. The relief valve is the top fitting.
Tue, Dec 14, 2021 12:10 AM
D2Fred
Reply to josh:
I received my new impeller finally. It had a hardened washer made onto the front of the impeller just like original. Thanks for the heads up on the relief valve, when I tore it down I figured it out, mine don't look like it could have done much reliving though. The port was full of hard black grease. Here is a good one for you, make sure yo dig that washer out that is in the impeller or it will come out in about three pieces! mine had so much crud in there that looked like it was part of the impeller.
Wed, Dec 15, 2021 12:30 AM
Reply to D2Fred:
Thats what happens when it gets over greased and doesn't have a relief valve, it pushes past the seal and fills the hub with grease.
Wed, Dec 15, 2021 4:51 AM
