D2 Upper Rollers
D2 Upper Rollers
Showing 1 to 6 of 6 results
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
My D2 (4U1826) is missing the upper rollers.  Were these likely removed by a previous owner or were some units built without them?
Sun, Nov 7, 2021 7:19 PM
Busso20
Thank you received: 31
my 1938 3J 1920 D2 has no load rollers on it, 4 track rollers only, check for mounts you will know then if factory fitted or not.
Sun, Nov 7, 2021 7:53 PM
GrantJ
Thank you received: 13
Reply to Busso20:
I have read that they were an option. I have a D2 with them and one without them. Since D2s seem to last forever, I doubt that they make a lot of difference, but it makes the machine look better. (IMHO) Grant.
Sun, Nov 7, 2021 8:29 PM
gauntjoh
Librarian
Thank you received: 8
Reply to GrantJ:
Top rollers on D2s are very rare here in the UK.
They were an optional extra and presumably due to WW2 shortages very few if any arrived on these shores with top rollers.
Sun, Nov 7, 2021 8:38 PM
Cat Yellow1
Reply to gauntjoh:
Thanks everyone. Sounds like this might have never had one.
Mon, Nov 8, 2021 7:18 AM
josh
Thank you received: 14
Reply to Cat Yellow1:
On the early 4U D2s the track carrier roller was an option, the later 4Us it was standard, I have an early one that has the upper roller 4U1098SPG, maybe that is what the SPG is for.
Mon, Nov 8, 2021 8:45 AM
Reply to josh:
Added track weight is a consideration.....
  [attachment=65273]D2 Carrier Rollers.jpg[/attachment]
Mon, Nov 8, 2021 8:56 AM
