D2 transmission bearing race removal
Showing 1 to 10 of 19 results
bpusmc
Send a private message to bpusmc
 [attachment=67127]90198D70-EE33-48EC-82D3-08F246405FFA.jpeg[/attachment] [attachment=67127]90198D70-EE33-48EC-82D3-08F246405FFA.jpeg[/attachment] [attachment=67128]B410FFE6-41D8-4561-9F8C-FCA9272EA8CA.jpeg[/attachment]
Can the bearing race (identified by the yellow arrow) be removed through the front of the casing?  If so, how?
Thanks,
Chad
Thu, Mar 10, 2022 10:20 AM
bboaz
I just removed a similar bearing on a 955 transmission, which is a D-4 transmission.  The bearing was a roller bearing with cylindrical rollers The part of the bearing holding the rollers in place came apart and dropped 12 of the 15 rollers in the transmission.  I fished them out with a magnet.  I turned a ring which fit over and clamped to the race, then used a puller similar to a steering wheel puller to pull the race off the shaft. The split ring was held together with 5/16 inch socket head screws.  it took some time to tighten the screws with an Allen Wrench clamping the ring to the race  but it held the ring tight.  There was a 1/2 inch hole taped into the end of the shaft which I center drilled the head of a 1/2 inch  bolt and screwed it into the shaft to provide a center pint for the puller to keep it centered. My bearing race had a lip on each end so the ring would not slip off.  If your bearing race has a grove in it for the rollers of the bearing to run in, then make your ring so it fits into that grove.  To put the new bearing on, I screwed a piece of grade 8 all thread into the end of the shaft and used a nut, washer and the old race to push the new bearing on the shaft.  It was really tight and close but I was able to get the race off and new bearing installed without taking the transmission apart.  Brian Boaz
Picture # 1 The ring and the puller assembled as I used it
 [attachment=67129]20220309_214714[1].jpg[/attachment]
Picture #2  The ring and the puller taken apart
[attachment=67130]20220309_214803[1].jpg[/attachment]
Picture #3  The ring with the bolts that attach to the puller
[attachment=67131]20220309_214907[1].jpg[/attachment]
Thu, Mar 10, 2022 11:24 AM
Thank you received: 77
Reply to bboaz:
Nice!
Thu, Mar 10, 2022 8:20 PM
Nice!
Great going Brian!! You can tell that you are a machinist!
Thu, Mar 10, 2022 9:21 PM
bpusmc
Brian,
That’s a nice tool! I wish I had that capability.
Chad
Fri, Mar 11, 2022 9:15 AM
bboaz
bpusmc: If your bearing race has a lip on the outside or grove in the center and you can measure it with a set of calipers. I can measure the inside of my tool and see if it will fit your bearing race. if it will, I can send you my tool and you can use it to pull your bearing race off. If you have a puller like the one, I have pictured with a point on it. find out what size and thread the center hole in the shaft is and I can center drill a bolt to screw into the end of the shaft to hold a puller true. Isn't that what this ACMOC is all about? Helping and educating each other out to keep these old machines running. Brian Boaz
Fri, Mar 11, 2022 11:22 AM
Thank you received: 54
Reply to bboaz:
you can buy ready made bearing separators from any good industrial supplier, auto parts joint or tool shop. they come in a few different size ranges and for the smaller sizes under 100 bucks you can also get them as part of gear puller sets.
Fri, Mar 11, 2022 1:27 PM
Reply to trainzkid88:
Use heat tip on a torch, heat it up quick, it'll slide right off.
Fri, Mar 11, 2022 8:08 PM
You're a champion Brian! : )
Fri, Mar 11, 2022 8:26 PM
bpusmc
 [attachment=67138]566D8916-F0C9-4CF4-A6FD-CFA790E03765.jpeg[/attachment] [attachment=67139]EDD2512F-1F7D-4FA6-A898-0B8712101730.jpeg[/attachment]bboaz: Brian, thanks for your generous offer.The new race OD is 1.49” and is completely smooth, no lip or groove (see photo). I threaded a piece of 1/2” 20 allthread in the center hole in the shaft. To humor you, the last picture is my shade tree mechanic attempt at making a puller. I didn’t want to give up without trying something!! I’m anxious to get this thing put back together and really appreciate your help.
Chad
Sat, Mar 12, 2022 2:24 AM
Reply to bpusmc:
Chad
When I had a bearing race like that to remove (bevel gear shaft in rear of transmission), I sliced it with a gas axe. I shielded it up with some plate, heated it first with a mapp gas torch, then hit it fast and hard with the axe. I didn't cut all the way to the end, just about 75% of it. A cold chisel opened up the rest. It came off but if it didn't, my next step was going to be welding something to the split end so I could grab a hold of it and pull it off. A small scour on the shaft but otherwise unharmed. Tractor seems to work ok! : )
Sat, Mar 12, 2022 5:06 AM
