D2 track swap
D2 track swap
Will 5J tracks fit on a 5U tractor?
Sun, Nov 16, 2025 4:11 PM
Thank you received: 73
Yes, if the 5U is prior to 13273. If it's after that serial #, you'd need to add three to five links depending on options. Post-5U13273 has longer track frames with 33 std links vs. J-series with 30 links
Sun, Nov 16, 2025 5:53 PM
Mine is 5U0928, so a very early version (1948, I believe). I will have to do some measurements to be sure, but they are in better shape than what I have now. I am in the process of rebuilding the steering clutches, so now would be a good time.
Sun, Nov 16, 2025 8:18 PM
Sounds good. Feel free to post some photos : ) We like to ogle machine pictures!
Mon, Nov 17, 2025 4:27 AM
CatD2
Send a private message to CatD2
JM, where are located? I ask because I have come across a few salvage D2's in my general area (central NY) with halfway decent tracks, that I have passed on since mine are ok. With you location, members might be able to help you locate some.
Mon, Nov 17, 2025 12:47 PM
CatD2, were any of those Central NY tractors later model ones, post-5U13273? Reason I ask is I'm looking for track frames and I'm in Rochester
Mon, Nov 17, 2025 1:58 PM
CatD2
Neil,
Yes, I know you've been looking for tracks. It was an ad in FB over the summer, for an older D2 in a scrapyard somewhere. Now, I don't see it any more on FB. I should have posted the link when I saw it, so anyone in need could be alerted. If its any consolation, I think it was a regular frame one.
Mon, Nov 17, 2025 9:44 PM
righto thanks CatD2, I have a terrible memory so I'm sure I'm going to ask you again before too long! : )
Mon, Nov 17, 2025 10:23 PM
CatD2
Neil,
When I went to my Kindle, I found the saved FB listing. Here it is below. I'm not sure of the year, or even if it is still available, but happy hunting anyway.
https://www.facebook.com/marketplace/item/3873875809608917/?rdid=RdPWzkzTYQHo79HN&share_url=https%3A%2F%2Fwww.facebook.com%2Fshare%2F1C4YUAp1WB%2F
Tue, Nov 18, 2025 3:51 PM
| Kingaroy, Queensland
