d2 to d4
Hobo groh
Send a private message to Hobo groh
hello i was just wondering if it is possible to re power a d2 whit a d4 engine thanks an 5u series
Tue, Aug 13, 2019 9:38 PM
STEPHEN
Not as a direct bolt on, but anything is possible. Everything after the engine would suffer. I think the bevel gears are already the weak link as most of the D2's I have dismantled had chipped or badly worn teeth on the bevel pinion.. There was a field change with an improved bearing on the bevel pinion. I'm surprised that no aftermarket developed an intermediate torque converter drive to bolt between the flywheel housing and transmission.
Wed, Aug 14, 2019 6:12 AM
Hobo groh
Reply to STEPHEN:
I think it would be cool if I was going to do it I would have upgrade the transmission
Wed, Aug 14, 2019 8:20 PM
