D2 steering clutch disks
Showing 1 to 10 of 17 results
Arborigine
Send a private message to Arborigine
I won't be able to afford a new set of disks and steels for a while.
I do reline old racing brake shoes and pads occasionally at work, the owner of Tilton is a friend of my boss and we are also a Ferrodo dealer. I can reline the disks myself and have the machinery required.
I have not removed my clutches yet, as I can't afford to let the Cat sit in the way for too long. Does anyone have a loose NOS or relined clutch disk for getting dimensions?
Wed, May 4, 2011 7:57 PM
daron
You might call John Parks at General Gear in Boise, ID. His company sells used and aftermarket parts and I'm supposing he could supply you with the dimensional information you're looking for.
His company has a website: http://www.tractorparts.com/
Daron
Wed, May 4, 2011 10:38 PM
Mike Meyer
Thank you received: 6
Reply to daron:
Daron
My fibres have not been relined yet, but I'd assume the best of them are about 20% worn, so use the thickness as a loose guide.
Outer diameter of fibre band, 9.5"
Inner diameter of fibre band, 6 3/4"
Steel plate thickness, 0.06 thousands of inch
Thickness of plate and it's two fibre bands, .320 thousands of inch
Hope that helps
regards
Mike
Thu, May 5, 2011 4:48 AM
Reply to Mike Meyer:
Hope that helps
regards
Mike
Fiber material would be 0.125 inches thick based on Mikes measurement.
Thu, May 5, 2011 6:09 PM
Jason 10/D4
Reply to drujinin:
You can buy new disks from general gear for about half of what cat wants for them. They are $22 for bi metalic and $12 for the steel. Most of the time you can clean the steel up and reuse if your not gonna work her every day and the teeth on them arn't to pitted or eaten off . Jason
Thu, May 5, 2011 7:42 PM
Arborigine
Reply to drujinin:
Mike, that helps a lot, still have to figure new thickness. I assume the steel thickness given is the plate the linings are riveted to and not the bare plate? Without a new one to measure the linings minus steel are,
.32 -.06 = .26, .26/2= .13., .13 + 20% = .1338 . I think it more likely that the original thickness would have been a normal fraction such as .1406 (9/64) or even .1562 (5/32).
I don't know where Drujinin got .125
Thu, May 5, 2011 7:47 PM
I would look up a "stacked height" for the clutch pack and calculate from that. I know there have been quite a few questions about how many of the thinner bimetallic discs to use when converting one, so you should be able to find it.
When you're looking at the dimension of 2 linings and the steel plate they're riveted onto, you're going to pick up a thousandth or two until it is compressed in the stack.
Thu, May 5, 2011 8:25 PM
I forgot all about the 20% wear factored in! I just figured 5 thousandths for ono-compressed. Thanks for pointing that out! 👍
Fri, May 6, 2011 12:31 AM
Mike Meyer
Reply to Arborigine:
[quote="Arborigine"]Mike, that helps a lot, still have to figure new thickness. I assume the steel thickness given is the plate the linings are riveted to and not the bare plate? Without a new one to measure the linings minus steel are,
I don't know where Drujinin got .125[/quote]
Correcto Mondo, The steel thickness was for the plate the fibers attatch to, interestingly I'm chatting to Dana at Florin Tractor Parts right now via email about buying new fibers for my RD6 steering clutches, it seems each fiber is around $30 each from Florin, and $50 each from another supplier.
At those prices the newer bi metallic plates from General Gear look pretty attractive even if you do need a couple extra plates. If you check over on the General Gear website they list the specs for steering clutch thickness.
Good luck
Mike
Fri, May 6, 2011 1:08 AM
chriscokid
Good luck
Mike
here is the link to the D2 clutch info
http://www.tpaktopc.net/d2strcltch.htm
Fri, May 6, 2011 2:35 AM
Arborigine
Reply to chriscokid:
I talked to my supplier today and i almost called Oleg "Peggy", he sounds just like the guy on the TV commercial.
Basically he doesn't know unless i send him the plates and thickness is still a guess. Sounds like there are too many hours labor involved to take a risk with parts that might work.
Sat, May 7, 2011 11:30 AM
