D2 starts too quick?
Showing 1 to 10 of 15 results
Sweet D2
Send a private message to Sweet D2
I'm still getting acquainted with my D2, never having had one before.
I read much about the starting procedure with my pony motor etc. and it all works fine until.
Everything I read said it might take minutes for my main to get warn enough to run on it's own.
But my main will start in cold weather even after the pony spins it for as little as 15-30 seconds.
Am I doing something wrong or dangerous? Or should i just be happy?
My unit has 2400 hours on it and sat in a shop idle for the last 30 years.
D2 3J68xx
Kern Co, CA
[email][email protected][/email]
Tue, Feb 5, 2013 12:24 PM
wendell f. stegner
Send a private message to wendell f. stegner
I think I'd be happy. What do you call Cold weather? I'm alittle green also but have a D6-9U that starts very well at 30 degrees. I can just let pony rolling main engine long enough for me to check oil pressure and then get myself back into position and start main engine. Fire in the hole!! Puts smile on my face every time.
Have fun, be carefull,
Wendell👍
Tue, Feb 5, 2013 11:36 PM
rjh-md
Be thankful that you have an engine with very low hours on it !
Crank over the diesel engine with the compression lever in the start position ,so the lever is pushing the intake valves open ,and releasing the compression .Watch the diesel engine oil pressure gauge ,and turn compression on when you see that the oil pressure is up to the maxium ,and let her run and purr like a kitten !
Tue, Feb 5, 2013 11:39 PM
cojhl2
Reply to rjh-md:
You are leaving the fuel off until you want it to start aren't you?
Tue, Feb 5, 2013 11:45 PM
Reply to wendell f. stegner:
Wendell👍
Yes, what is "cold weather"?
My Two Cents is that the Manuals all say to wait for this to happen and that to happen.
I do AGREE that the longer it spins, the more the oil gets pumped around thus building pressure, the main heats up more due to warmer coolant and manifolds while the cylinders build heat.
BUT!
What happens to all those requirements when a guy buys one with a Factory electric start or removes the Pony to install an electric start?
SO
In conclusion I would figure if it starts up with in 30 seconds, then AWESOME!
Tue, Feb 5, 2013 11:46 PM
ag-mike
Reply to drujinin:
BUT!
SO
start according to the manual, sounds like your leaving the fuel and compression on. diesel must spin (not running) for awhile to get oil pressure up and lubing, THIS IS VERY IMPORTANT. again start according to the manual. good luck.
Wed, Feb 6, 2013 12:06 AM
Inter674
Reply to ag-mike:
I recall previous comment here that each machine is different, and they will behave differently over time too. I saw a D2 that had not been started from many months start easily. The pony took 2 pulls, and away it went. The starter clutch was engaged, main engine spun over for a matter of seconds while the oil pressure was checked. Thumbs up👍, decomp in and away she went. Total time? About 20 seconds from pilot revving to main running,
But, the same machine at my place did not behave as well, taking ages to get the pilot going, and a lot longer than before to start the main! Figure that one if you can. My D4 is different again and takes quite a lot longer than the D2 to get the main firing nicely even though the motor is reconditioned.
Clearly there are many factors affecting starting times - engine condition, timing, fuel quality, filter state/fuel pressure, ambient temp, injector efficiency, operator technique and so on.
So enjoy the regular easy starts while you can:flypig:
Wed, Feb 6, 2013 2:46 AM
catsilver
Reply to Inter674:
I always found it easier to get a clean start by leaving the throttle closed and going to full compression as soon as the oil pressure built up, then wait until the engine starts to 'beat' before opening the throttle, then they will fire straight up. Running on full compression is far more effective in warming the cylinders then the pony exhaust going through the inlet manifold.
Wed, Feb 6, 2013 8:14 PM
Sweet D2
Reply to catsilver:
Thanks for all the feedback; just wanted to be sure I wasn't harming anything.
Cold weather start here is Central Ca. is 30 degrees.
Yes, I do leave the throttle closed and the compresseion release on until I see oil pressure.
After applying compression, I then wait to see some black puffs from the main stack and then I think what i hear "Catsilver" calls the engine "start to beat" and then I crack the throttle.
She usually takes off in about 10 more seconds.
Thanks again for all the operating input.
D2 3J68xx
Kern Co, CA
Fri, Feb 8, 2013 11:44 AM
Soapy
Send a private message to Soapy
Reply to Sweet D2:
Sweet D-2
I presently own two D-2s, the one I got from Mike Mc, out in the thriving community of Rosedale, starts very much like yours. The other one takes a little longer, and only wants to run after the pinion kicks out.
Must be the colder weather up north here in Visalia!! lol
Fri, Feb 8, 2013 1:56 PM
Soapy, I had a 212 grader with the D311 engine that acted like yours. I learned to listen to it and the pony motor and disengage the pinion clutch to let it speed up and kick the pinion out. If I disengaged too soon, it would die out, but usually it would immediately speed up.
The engine had good power and would lug like nothing I'd ever seen before, but it was far from new.
Fri, Feb 8, 2013 2:04 PM
| Kingaroy, Queensland
