D2 Starting Engine
D2 Starting Engine
RossM
Send a private message to RossM
Has anyone had to put valve seat inserts into a D2 Starting engine or know where I can get some made
regards Ross
Fri, Apr 28, 2017 12:33 PM
rmyram
i had valve seat inserts installed on a d6 pony engine, i had to find a shop with older equipment as the pony would not fit in the some of the newer valve repair equipment,
Fri, Apr 28, 2017 9:52 PM
Online
Thank you received: 58
Reply to rmyram:
Ross, I had inserts put into both my 3J and 5U main engine heads. When I asked the guy about sourcing the inserts, he just said that he gets "generic" of the correct size. Worked for me so I guess your local shop can do the same thing for the pony.
Sat, Apr 29, 2017 12:44 AM
RossM
Thanks Neil,
I will give that ago
Cheers Ross
Sat, Apr 29, 2017 6:26 AM
