D2 starter pinion question
Showing 1 to 10 of 14 results
n2s3
Send a private message to n2s3
Finishing up with My D2, finally getting it going. my question is when starting, after starting pony and engaging pinion, everything is ok but when I push the compression release the pinion disengages and the main stops turning over. Do I need to adjusted release adjustment screws 1/2 turn in? not sure if its a rpm issue or worn out latch? I find I have to hold up on the pinion to keep it engaged.thanks for the help. Bryan
Sat, Aug 20, 2016 12:23 PM
sr4440
Send a private message to sr4440
You might need to tun the screws on the latches in.
Try loosening off the clutch engagement one notch. I had the same problem with both of my d2's and that seemed to do it. Easy to do
Sat, Aug 20, 2016 7:21 PM
Thank you received: 61
Reply to sr4440:
If turning the screws in a half or full turn does not noticeably improve things, then inspect your latches. The "catching" edge may be worn and you'll need to either dress them or replace them
Sat, Aug 20, 2016 7:25 PM
when you push the compression release in is the throttle fully closed?
Sat, Aug 20, 2016 8:57 PM
Thank you received: 46
Reply to dpendzic:
Sounds more like the mounting bolts have dropped out of the pinion engagement sleeve. Holding the pinion engaged will take its toll on the engagement lever.
Sun, Aug 21, 2016 1:27 AM
n2s3
Thanks for the replies. dpendzic: yes the throttle is fully closed.OM: I had the pinion out of the tractor when I split it for main clutch replacement. there was some wear and the screws were out as you mentioned.I bought new ones with new locking tabs. I will try the adjustment and keep you posted. thanks again,Bryan
Mon, Aug 22, 2016 3:29 PM
Reply to n2s3:
Usually the screw threads get buggered up in the process. If so, new screws and tabs won't hold.
Mon, Aug 22, 2016 9:04 PM
n2s3
well the adjustments were no help.will have to take it back apart and replace the latches at least.Bryan
Wed, Aug 31, 2016 10:32 AM
n2s3
Reply to n2s3:
well, I took it back apart, sort of surprised that there is minimal wear on the latches.the stop has a slight radious.I have new latches from Florin tractor and will try to get a new stop. My manuals don't mention how to set up the latch tension after replacement,other than counting the threads on the originals ,and that they are factory set at a certain rpm.(Iam guessing on a bench test of some kind) So match the originals and trial and error? Thanks,Bryan
Mon, Sep 5, 2016 8:57 AM
Reply to n2s3:
Are the latches centered on the ears of the stop? Not off towards the flats. Sometimes a shim washer needs to be added under the stop to get the correct orientation.
A starting point for the latch adjustment is when the screw heads a flush with the sleeve.
Mon, Sep 5, 2016 9:05 AM
You could also turn the stop down a few thou to remove that radius. As I recall, that head is about 1/4 thick? Probably take 050 off with no problem.
Mon, Sep 5, 2016 9:14 AM
