d2 starter
d2 starter
Showing 1 to 6 of 6 results
2bluejon
Send a private message to 2bluejon
i am needing some help on a D2 starter i was wondering if some one had the # on the nose end housing and if some one knew how many teeth i need thanks vern j
Tue, Apr 21, 2009 3:25 AM
raklet
Send a private message to raklet
Here is direct from Old Magnet.
[img]http://img400.imageshack.us/img400/3194/ahpage051ch.jpg[/img]
If you want to read the rest of his booklet about starter conversion (there is a section devoted just to D2s), you can find it here:
http://img400.imageshack.us/gal.php?g=header4oq.jpg
Tue, Apr 21, 2009 7:30 AM
2bluejon
Reply to raklet:
Hey this is vern and i was wondering i found some parts on ebay and was wondering if they would work thanks vern there they are or do i need to find somthing else 307-880-9097
E-BAY
Item number: 260298151914
Item number: 250235503003
I am looking at getting a 42MT starter i found some used ones for a perty good price
Tue, Apr 21, 2009 11:45 AM
Reply to 2bluejon:
E-BAY
The starter drive is a good number.
The housing is for a 40MT starter .....not the same as a 42MT....will work but you won't have the "O" ring seal that the 42MT housing has. See the web site for picture comparison.
Tue, Apr 21, 2009 9:46 PM
jmvmopar
I got a 42MT rebuilt off of ebay today for $161 with shipping. I crossed their number to napa's and it shows cw rotation.
Got the DEH and helix for under $100 too. They showed OldMagnets part numbers as a reference number.
I just had to double check to make sure I didn't steal your items. I didn't so all is good.
Wed, Apr 22, 2009 12:06 AM
2bluejon
Reply to jmvmopar:
is the drive end housing good other that the o ring or can someone help me fint the right one on e bay if so what is the item # thanks
Wed, Apr 22, 2009 10:34 AM
raklet
Reply to 2bluejon:
Yes, the housing is good. The housings are all interchangeable between the 40, 42, and 50.
Wed, Apr 22, 2009 11:01 AM
