D2 Sprocket
D2 Sprocket
Showing 1 to 6 of 6 results
dan83
Send a private message to dan83
Hey there hoping someone would know a part number for a berco weld on sprocket someone changed one of mine to a berco the other is junk so id like to get another berco if anyone can help that would be great thanks dan
Fri, Jan 18, 2013 10:59 AM
Steve A
I believe you can use the rims for a early D3
Fri, Jan 18, 2013 6:49 PM
Thank you received: 60
Reply to Steve A:
Be aware the bushing diameter for the D2 is 1.69".
The D3 bushing diameter is 1.85".
I don't have the Berco # but the Cat # for the D2 rim is 7H0463.
Fri, Jan 18, 2013 10:56 PM
invisabledog
Send a private message to invisabledog
cr962 appears to be the berco number.
Fri, Jan 18, 2013 11:23 PM
Gregness
Reply to invisabledog:
Let us know if you succeed in finding one!
Sat, Jan 19, 2013 12:26 AM
dan83
Reply to Gregness:
the good sprocket is the berco the worn out one is original i think its pretty thin thanks for all the help[attachment=15971]Photo0461.jpg[/attachment][attachment=15972]2013-01-17_14-04-06_843.jpg[/attachment][attachment=15973]2013-01-17_14-04-27_497.jpg[/attachment]
Sat, Jan 19, 2013 5:43 AM
Gary Morisoli
Send a private message to Gary Morisoli
Reply to dan83:
Florin tractor has 1 sprocket with a good ring welded on it. It has very little wear.
I saw it there yesterday.
Gary
Sat, Jan 19, 2013 6:58 AM
