D2 shifter boot
D2 shifter boot
Showing 1 to 10 of 15 results
Potato Wilson
Thank you received: 23
Does anyone know where to get a shifter boot for a D2 5U? I tried the dealer but no luck.
Or maybe someone knows of an alternative boot that works?
There was actually quite a bit of laughter over the phone when “my” parts tech announced to her teammates that I was looking for parts for a 1948 D2. But someone helped out, and they dug into the “legacy” database and did manage to find a few of the parts I was looking for. 👍
Wed, Jun 18, 2025 3:09 AM
Thank you received: 52
try a decktite they come in several sizes.https://deks.com.au/product-category/dektite-rubber/
Wed, Jun 18, 2025 5:58 AM
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
I bought one for my 1949 4U about 5 years ago from Cat. If you create an account with Cat, you can order your own parts and pick them up at your local Cat store.
Wed, Jun 18, 2025 9:12 AM
Thank you received: 64
I too bought one from the dealer who had a good parts guy, since retired. That was back in 2014 so a whiles ago now unfortunately
Wed, Jun 18, 2025 12:45 PM
8C 361
Thank you received: 12
I bought a shifter boot for my 7U D4 from Amazon, just search by part number.
Wed, Jun 18, 2025 1:08 PM
Potato Wilson
So the parts diagram shows it as # 688528.
The dealer said it should be 8C 7436, but a general search shows that as a brake cylinder boot.
Wed, Jun 18, 2025 5:19 PM
Cat Yellow1
The boot for my 4u was 6B8528, but you should check the parts manual to make sure of the correct one for yours, as it could be different depending on your serial number.
Thu, Jun 19, 2025 12:15 AM
Potato Wilson
Reply to Cat Yellow1:
Ah Hah! Thank you for sharing that the # has a B, that I thought was an 8.
Thu, Jun 19, 2025 4:41 AM
Potato Wilson
Bingo! It popped right up on the Cat website. Thanks everyone!
Thu, Jun 19, 2025 4:52 AM
most cat part numbers for this old gear the second character is a letter. an exception is the hand grips for clutch levers on the crawler tractors.
Fri, Jun 20, 2025 6:48 AM
Msjoy
  • True sir. Part number is all the counter sales person needs. Most times he has it, on a few items he orders. But the days of just taking an item in and declaring you want one are gone. I’m not surprised the guys thought it was laughable. All on a simple item like this! Again thanks trainskid
Fri, Jun 20, 2025 10:58 AM
