D2 serial number Need help with year built.
Showing 1 to 7 of 7 results
rehpig
Send a private message to rehpig
Looking at a D2 5U5135. Can you folks help with some info on it. Birthdate etc
Fri, Jul 10, 2020 12:43 AM
chriscokid
its a 1950
Get this book: http://www.acmoc.org/store/index.php?dispatch=products.view&product_id=307
It covers all track type cat models up to 1960
Fri, Jul 10, 2020 1:36 AM
D4Jim
Might need a little extrapolating but the serial #'s from 1950 were 5U 4204 to 6671.
I noticed the Serial Number books are listed as out or stock in the ACMOC Store
Cats Forever
Fri, Jul 10, 2020 1:37 AM
rehpig
Reply to D4Jim:
Do you think this one has the removable clutch lid? Doesn’t have to be split
Fri, Jul 10, 2020 2:54 AM
Ron
Send a private message to Ron
Reply to rehpig:
That year would not.
Fri, Jul 10, 2020 5:32 AM
Reply to rehpig:
It would have the one piece trans/clutch cover.
Thank you received: 78
Reply to rehpig:
It is not a two-piece clutch shaft model. Engine needs to be separated from transmission to change clutch.
Two piece started with 5U13237
Fri, Jul 10, 2020 7:11 AM
