D2 Roller ID and compatibility
Jdnut
Send a private message to Jdnut
I have a set of D2 Rollers. 4 are double flange and 4 are single. All I can find on them for parts numbers are BERCO on one side of the mounting flange, and CR800 on the other side. There are the bushing style rollers.
My question, will the fit on a J series D2? They came off of a 5U.
Thanks!
Jdnut
Chris - Jdnut
Located in Stanwood, Washington
Collector Of:
Bucyrus Erie - 15B 20B 22B
Caterpillar - 8U D6, 3T & 4T D7
Kenworth - W900 & W925
John Deere - A's B's R's
Drott - 50 DC
Mon, Oct 29, 2007 7:11 AM
Jack
Hi Chris,
I checked my parts books. 5J and 5U used the same rollers on at least some of the series. They are to be arranged with single flange front and back, double flange in the middle two places. Rollers you have should work.
Jack
Mon, Oct 29, 2007 10:14 AM
Jdnut
Thankyou Jack!
Chris - Jdnut
Collector Of:
Drott - 50 DC
Tue, Oct 30, 2007 10:00 AM
josh
Thank you received: 13
Reply to Jdnut:
Thankyou Jack!
One issue you might have a problem with is most of the U model rollers have a grease fitting guard cast into the roller which will not fit with J model rock or dirt guards, you will often see J models that have had the grease fitting holes in the guards torched out to a bigger hole to accomodate the later rollers, if your rollers are the lifetime type without a grease fitting it will not be an issue.
Tue, Oct 30, 2007 10:25 AM
