D2 questions- from a newbie
Showing 1 to 10 of 12 results
B D Alexander
Send a private message to B D Alexander
I'm the proud new owner of 5U4848.  It has a stuck engine and reportedly a stuck steering clutch.  Are there sites that can rebuild the D2 for you (the customer).  Thanks for any information.
B D Alexander MT USA
Mon, Oct 17, 2022 10:40 AM
restore49
Do some research on freeing up the motor and you may find this is a job you can do yourself.
Mon, Oct 17, 2022 8:56 PM
Fat Dan
Reply to restore49:
There are a lot of good videos out there, Squatch253 has some great rebuild videos on D2, D4 and a lot of other great information. Hamiltonville Farm dose a lot of will it start videos give you some ideas.
I'd get manuals operators & maintenance manual, Parts Book and service manual. These are a must if your serious; they do have a great online library here for members. Ebay also has most of what you'll need.
Tue, Oct 18, 2022 3:46 AM
Thank you received: 32
Reply to Fat Dan:
To answer your question, you might call Chad Enyeart who bought Zimmerman's in Laramie WY who I think restores old tractors possibly. antiquecrawlerparts.com
Tue, Oct 18, 2022 3:50 AM
Delta KJ
If you are mechanically inclined and have an interest in working on the tractor then you should get the Caterpillar "Serviceman's Reference Book" (service manual), the Operators and Parts manuals.  They are readily available on the popular auction website.  These tractors are not complicated and are not difficult to work on if you have an inclination and enjoy such things.  The Serviceman's Manual is well written and is very informative.
Frankly, I don't know why one would buy one of these tractors if one weren't inclined to work on them.  Regardless, if you don't want to work on the tractor then I suggest posting a "Caterpillar Mechanic in Montana" on in this forum to solicit someone here to help you find someone in Montana.
Tue, Oct 18, 2022 6:32 AM
Thank you received: 149
Reply to Delta KJ:
Easy there Delta KJ, let's give him credit for becoming a paid member! He may have reasons for owning and either unable to work on it himself or enjoys enlisting those that are able; I have plenty here, and cannot/will not do everything myself, when I am so fortunate to have an old CAT wrench hand available one hour away. I could make a full time job working on these critters here. My schedule does not afford me to do so, even if I wanted to do everything. Not everyone is able to afford the equipment needed to repair as well. It takes years to accumulate hand tools, jacks, presses, hoists, forklifts, etc.
Sorry to say I do not know of anyone in Montana that works on D-2s.
Please share photos of your tractor at least, I am sure many would like to chime in with more "help". JM
Tue, Oct 18, 2022 8:18 AM
Kurt Bangert
Thank you received: 30
Fat Dan has some good suggestions and Juiceman has the spirit. I would recommend Pacific Northwest Hillbilly on YT too, he shows you what can be done if you are determined.
Good luck and welcome to the nuthouse!
Tue, Oct 18, 2022 8:31 AM
B D Alexander
Reply to Kurt Bangert:
Outstanding replies. Thank you guys! I'll take your advice and seek out the parties mentioned. I'm afraid I don't have enough time left to learn the trade and get the tools to do it myself. I can't stand to see such a well designed piece of equipment sit idle.
B D Alexander
Tue, Oct 18, 2022 6:35 PM
d2gary
Reply to B D Alexander:
B D Alexander
What part of Montana, there might be someone close by that would be willing to help you out.
Tue, Oct 18, 2022 8:37 PM
B D Alexander
Reply to d2gary:
Great Falls
THX
Tue, Oct 18, 2022 9:48 PM
Thank you received: 42
Great Falls
THX
as these are rather basic machines any older diesel mechanic can work on them young blokes can too if their willing to learn(the basics of engines haven't changed in 100 years we just have better materials and tolerances today and the electronics). some of the tooling for the special jobs is still available. and yes get a copy of the three manuals as others have suggested.
the dealer mechanics will work on this gear for a fee of course and that fee aint cheap. for parts try the dealer if you have a part number they can help you so a parts book is a must have.(note there are separate manuals and parts books for the engine and attachment such as blades and hydraulics units)
the challenge is finding a diesel mechanic willing to have a look.
i would start by removing the manifolds clean out any dirt and remove the injectors so you can pour diesel down each cyl followed by draining the engine oils checking for signs of water in oil if no water that's a good sign refill with fresh 15w40 diesel mineral oil. if you cant remove the injectors drain the rad and pull the heads remove any dirt found and add diesel let it soak for a few days top up the diesel as needed using a block of wood and hammer give each piston a tap. if you can get the engine turning over thats half the job.
Thu, Oct 20, 2022 3:32 PM
