d2 questions
d2 questions
ou812jk
Send a private message to ou812jk
what size plug wires for pony motor ? also been along time since I took it apart to paint what way does the vent on intake of pony motor go the little square block on top of carb with 1/2 pipe coming out for a hose connection and where is that hose go
Sun, Aug 26, 2012 8:21 PM
randy merrick
Send a private message to randy merrick
Good Morning
The inlet on the square piece above the carb is for the crankcase breather connected to the oil filler tower. Originally I believe they were a one piece, welded pipe, configuration between the oil filler and the square block.
My plug wires are 18" long and the other 24". I have always heard they should be actual metal wiring.
Good luck and have fun working on it.
Sun, Aug 26, 2012 10:14 PM
D4guy
Send a private message to D4guy
Hi ou812jk,
Here is a photo of my pony. The tube on the block on the carb goes to the crankcase breather/oil fill housing. The blue tape covers the opening where the pipe from the air cleaner is mounted.
My pony came with modern resistor wires which seem to work ok. I will replace them with more correct copper wires someday if they give me trouble.
[attachment=14181]IMG_0161.jpg[/attachment]
1955 D4 Traxcavator, 1926 Model T Roadster, 1930 Model A Tudor, 1940 Diamond T 201, 1954 JD 40 dozer
www.mervbergman.net
Sun, Aug 26, 2012 10:28 PM
