D2 question
D2 question
RayMiller4288
Send a private message to RayMiller4288
I have a 1953 model d2 5u that I'm trying to take the water pump out of. I'm having troubles getting the fan belt to come loose. I took the fan blade off and I think the bearing are bad. I was wondering if the 44 model hydraulic unit would come off with the radiator in one piece? Thank u
Wed, Jul 19, 2017 7:05 AM
Thank you received: 63
Ray have you removed the two locking tabs in the threaded portion behind the rear rim of the fan pulley? If so and it still doesn't turn, get a screwdriver and gently lift in the slot where the two tabs are, to relieve the binding pressure on the rim so that it can be turned. Spray plenty of penetrating fluid on those threads and work the rear rim to and fro relative to the front rim to loosen it up.
I'm planning to remove my radiator next week with the #44 attached as I just bolted it up and now need to change out a gasket behind the front accessory drive cover.
Wed, Jul 19, 2017 7:17 AM
RayMiller4288
I took the two bolt out and the retainer out and been soaking for about two weeks. I took the fan blades of and the bully and the bearing seem to lock up that I can't turn it?
Thu, Jul 20, 2017 8:44 AM
Reply to RayMiller4288:
Ray, here's the split in the rear hub I mentioned. If the retaining bolt had been tightened really tight, that split might not be releasing fully. Carefully insert a screwdriver and pry it open a little - not too much to break it. Do both splits, 180 degrees apart. Then check that there aren't burrs on the edge of the retaining lock slots in the front / threaded hub. There's nothing else that should be preventing it from turning other than damaged threads.
[attachment=43761]IMG_6529.jpg[/attachment]
Thu, Jul 27, 2017 7:28 PM
restore49
That slit( both of them) should be around .075 for the 30 degrees or so each one covers. If they are crushed in with the bolt to far could have skipped a thread. Not a lot of thread area covered by the rear hub so it would have to be really rusted bad to stick. So gentle tapping with a brass drift and heat may help. The tensioner will turn even if the pump is locked up.
Thu, Jul 27, 2017 8:29 PM
Since you are taking the water pump off anyway, just unbolt it, let it tilt down to slip the belt off and then you can deal with the adjuster later. Note, you want to remove only the section of the pump just behind the pulley, not the whole housing that connects the block and head.
Thu, Jul 27, 2017 10:25 PM
