D2 PTO seals
D2 PTO seals
catsteve
Send a private message to catsteve
Hello everyone.
Could someone please advise the Seals and gasket part numbers to change out a Rear PTO seal on a D2 4U.
I think there a few to replace. ?
I dont have a Parts book available to me at the moment otherwise i would have looked them up. Thank you.
Steve
Tue, Jun 11, 2013 12:16 PM
Steve A
I believe there is a service kit, I got one for mine 3 or 4 years ago, it even included the small seal for the shifter shaft up top.
The cost dosent stand out in my mine so it must have been reasonable.
Tue, Jun 11, 2013 5:04 PM
Thank you received: 77
Reply to Steve A:
I have the parts book for 5U13237 up, and it has the 540 (545,54😎 rear PTO parts listing but doesn't show the part number for the shaft seal on the rear (that faces the implement) - just the gasket 4B9334 gasket that you'd replace when splitting the PTO gear case. You might just have to pull it out and measure it unless someone else has a diagram that shows that part number.
Cheers
(Update - I see that there are two seals 2B1869 shown for the input shaft (from the engine) so I'm guessing it's the same seal for both the input and output shafts - someone else can chime in and confirm)
Tue, Jun 11, 2013 6:03 PM
Mike Meyer
Thank you received: 6
Cheers
[quote="Neil"]I have the parts book for 5U13237 up, and it has the 540 (545,54😎 rear PTO parts listing but doesn't show the part number for the shaft seal on the rear (that faces the implement) - just the gasket 4B9334 gasket that you'd replace when splitting the PTO gear case. You might just have to pull it out and measure it unless someone else has a diagram that shows that part number.
Cheers
(Update - I see that there are two seals 2B1869 shown for the input shaft (from the engine) so I'm guessing it's the same seal for both the input and output shafts - someone else can chime in and confirm)[/quote]
Hi Steve and Neil, My 5U1 to 5U13236 book says the same P/N's, if you want to remove the whole unit there is also the gasket 5B0849 up against the tranny housing.
regards
Mike
Wed, Jun 12, 2013 4:04 AM
catsteve
Reply to Mike Meyer:
Cheers
regards
Mike
Thanks for the replies everyone.
regards
Wed, Jun 12, 2013 5:22 AM
