D2 pony parts?
D2 pony parts?
Sf1066
Send a private message to Sf1066
Well I got the pony off my D2. The crank has serious play and the key for the ballencer has a slopped out slot. So I need to look into some parts pricing. Where do you guys look for pony parts? Likely need a crank and bearings. I didn’t pull the crank out yet but I can see needing to do the whole thing. I need to evaluate whether I want to keep moving forward with this project. I want to just not sure how much money I want to dispose of in the process. Thanks again.
Mon, Jun 15, 2020 5:54 AM
Thank you received: 78
If you grind the crank and put in new bearings, seals, rings, you're looking at about $800 last time I did it.
Mon, Jun 15, 2020 6:44 AM
Florin Tractor, California.
Mon, Jun 15, 2020 8:13 AM
I have also had those keyways welded and recut, of coarse they get cut back to exactly where they were or else. Even the had the area where the gear fits built up and reground, the gear was loose and just slid on before.
Mon, Jun 15, 2020 8:14 AM
d2gary
Check the for sale section I think Gemdozer has some pony parts still.
I have a couple of pony motors tore apart and might be able to help also
Mon, Jun 15, 2020 8:33 PM
gemdozer
Thank you received: 25
Reply to d2gary:
Have no more D2 poney crankshafts and carburators for now
Tue, Jun 16, 2020 12:54 AM
