D2 pony motor won’t run on both cylinders
Showing 1 to 10 of 18 results
Tad7561
Send a private message to Tad7561
Hey all so I’m kinda stumped on my D2 pony, it will run on one cylinder but not the other it has spark to dead cylinder, I’ve pulled carb apart and it’s clean. what could be making the one cylinder dead?? It has compression, better compression then one of my running engines. It dumps lots of gas into the cylinder that’s firing but not nearly as much to one that doesn’t also.
Spark is good on both cylinders as well, machine was running and used parked at end of day and now won’t start
Wed, Sep 11, 2019 12:47 AM
rax200
Hi Tad7561,
Have you tried putting in new plugs in as the can fail under compression, they may work fine when it is taken out but not under load.
Regards
Wed, Sep 11, 2019 3:31 AM
Tad7561
Reply to rax200:
Hi Tad7561,
Regards
I’ve swapped plugs and wires from working ponies and still nothing
Wed, Sep 11, 2019 3:43 AM
STEPHEN
Reply to Tad7561:
How about high tension leakage? Either in the cap or wires? Have you tried turning off the gas, opening the head drains and cranking until it fires? That what I do if I mess up and flood the engine. The left cyl seems to get crapped up more easily. I understand is common for the same cylinder to fire first,I know mine frequently does.
Wed, Sep 11, 2019 4:13 AM
Tad7561
Reply to STEPHEN:
The few times it starts on one cylinder is when we open gas for few seconds then shut it off, then after about 100 pulls it will pop off on one cylinder. We have also tried it with drains open and still only fires on one cylinder.
Wed, Sep 11, 2019 4:55 AM
cheshire cat
Send a private message to cheshire cat
Reply to Tad7561:
Had this issue ,drove me almost insane .. turned out be the cap tracking seems like the spark is still there, but its not at the right time !!
Did a valve job and rebuilt the carb made no difference fitted another cap and it ran like a top !!... hope this helps ...
Wed, Sep 11, 2019 5:08 AM
Tad7561
Reply to cheshire cat:
Thanks I’ll pull the cap from the D4 if that fails to be it I’m dragging it with the TD6 into the building
Wed, Sep 11, 2019 5:18 AM
Thank you received: 61
Reply to Tad7561:
Check you don't have a rag down the intake manifold runner to that cylinder
Wed, Sep 11, 2019 8:18 AM
Oldcarman
Send a private message to Oldcarman
It takes more ignition energy from the mag to fire under pressure. My vote is weak spark- - bad condenser, bad mag coil, bad points, low magnet charge.
Swap mags.
Thu, Sep 12, 2019 6:39 AM
Tad7561
Reply to Oldcarman:
Swap mags.
Don’t have a spare mag to swap, cap didn’t make a difference still won’t start.
Sun, Oct 6, 2019 8:48 AM
GrantJ
Thank you received: 7
Reply to Tad7561:
Try one of those $7 spark plug inline testers form Harbor Freight. Put it on the good side and see how bright it shows and then put it to the other side and see if it appears the same. If it shows the same, then points/condenser/coil etc are probably good. If it shows different, then you know something is wrong with the mag. It is cheap to do and might save you time and frustration. Just my 2 cents worth. Grant.
Sun, Oct 6, 2019 9:07 AM
