D2 pony motor installation help
n2s3
Send a private message to n2s3
just finishing up on steering clutches,main clutch,brakes and starter pinion on my '52 D25U. went to put the pony back on, was able to get the lower gasket and water seal from Cat, but can't find the number in my book for the exhaust gasket. (has a metal ring in the center) Also, is there another seal on the inside of the manifold that keeps hot pony exhaust separate from cold intake air? not sure what Iam looking at there. thanks for the help, Bryan
Tue, Jan 12, 2016 11:36 AM
Diesel Powered
Send a private message to Diesel Powered
I'm guessing you're looking at the parts picture for the actual pony engine (pg 35). There's another diagram on pg 8A that shows what you need in the top picture on the right/middle. Those pages may vary if you have a different manual (other than form UE01223😎.
As long as you're talking about the gasket where the pony exhaust goes into the diesel intake, it's part # 5F6839. The inner ring is part # 5F6994. There's a pipe assembly # 7F3028 that runs through the diesel intake manifold to keep the two separated. Somebody else may be able to help with first hand assembly experience since I haven't had mine down that far yet.
Wed, Jan 13, 2016 10:17 AM
n2s3
Reply to Diesel Powered:
Thanks for the help,that was the correct part number. For some reason my book does not have the page 8a, but the page with the pony motor is the same page number as yours. Go figure. Anyway, the pony installation is complete.thanks again,Bryan
Mon, Jan 18, 2016 9:39 AM
