D2 pony hot start
D2 pony hot start
Showing 1 to 10 of 10 results
Pioneer1930
Send a private message to Pioneer1930
Good Afternoon,
Im having a heck of a time hot starting my 1940 D2. It fires up when cold no sweat runs good. Go to start it after lunch....no dice... It has good spark, fuel but it just will not even pop once... Any suggestions? The entire machine was restored/ finished 2 years ago and is a great runner but the pony thing here is making me crazy. I don't want to modify it for electric as I restored it back to original. Thanks for any replies.....:frusty::frusty:
Mon, Oct 21, 2019 2:11 AM
Thank you received: 78
Sounds ignition related but to be sure:
- try starting it repeatedly. Then check if you have fuel smell coming out of the exhaust and/or plugs are wet. That will rule out a fuel problem
- replace condensor in the magneto. Report back with your findings
Mon, Oct 21, 2019 2:52 AM
Thank you received: 62
Is it a good blue spark when you try it hot. I believe once hot the mag will not be as hot a spark if the magnet is getting weak. But I am not that informed on a mag so maybe worry.
Old timers left them run all night to not have to deal with pony motor problems. Will be alright to idle for a extended lunch and siesta once in a while.
Mon, Oct 21, 2019 4:09 AM
Pioneer1930
Reply to Ray54:
I'm thinking I agree on the ignition aspect. Once it cools down it kicks off no problem. I moved it out of the woods and will check it out a little deeper tomorrow. I agree with leaving it running as I usually do but I was getting a little aggressive with an old brush pile that was half dirt and I killed it mid push....What do ya do....:doh::doh:
Thanks for the input, I appreciate it..
Mon, Oct 21, 2019 4:32 AM
Reply to Pioneer1930:
We had one in the Oil Patch 30 plus years ago with a "rebuilt" Mag that did the same thing! If you stalled it, you may as well go home or find something else to do! More than a few times, we pull started it after stalling. The one I have now has a "Good" Pony that starts Hot. I'll keep that tractor around forever because of that fact!
Mon, Oct 21, 2019 6:42 AM
STEPHEN
Reply to drujinin:
Had a similar complaint once or twice, it was due to the gas valve not shutting completely tight. Have you tried opening the cylinder drains and cranking say 10 times with no choke and gov set to all full ahead? That will usually resolve an over rich cylinder. I crank it until I get a few pops, then it's back to business.
Mon, Oct 21, 2019 8:46 AM
d4angelo
Reply to STEPHEN:
I had this EXACT problem on my 1948 D4 7U. When the pony was stone cold it would start like a champ. When both pony and diesel were warm, the pony would not even try to start. I changed the coil in the pony magneto and all problems went away.
Mon, Oct 21, 2019 9:56 AM
JackD6-5R
Reply to d4angelo:
My HT4 poney will not start when warm, spark ok when cold but very weak when warm.
Mon, Oct 21, 2019 11:10 PM
Pioneer1930
Reply to JackD6-5R:
Getting ready for the weather to clear and have been searching around for a replacment coil for my Eisimann mag. I'm sure someone out there could point me in the right direction for a replacement/rewind outfit? I e-mailed a couple of places I regularly do mag business with this morning but I thought I would throw it out here to see if there was a place I didn't know about.
Thanks again for the input...…..:tea:
Tue, Oct 22, 2019 9:38 PM
I sent my RC-2H to Steve Belanger at Mainely Magnetos and it came back in tip-top condition, fully restored, for about 350 clams if I recall correctly
Tue, Oct 22, 2019 9:45 PM
Pioneer1930
So i know this is a few weeks old but I thought I would post my solutions to my hot start problem. I did two things. The first thing I did was rebuild the carb with a factory Zenith kit. When I took the carb apart I found it still had the steel tipped needle and I had replaced the float when I was in it a few years ago so I tore it down, ultrasonic cleaned it and put it back on. I then went through the mag and during that process. I discovered my condenser was marginal under a heat test also the coil was just really weak.... I replaced them as well, charged up the magnet and put the whole works together. 1 pull on the rope at 25 degrees F and it started right up, ran smooth. 1 pull on the rope directly after shutdown from 4 hours of moving 16 inches of snow, fired right up no trouble. I'm pretty sure the Mag was the cuprite as I found performance issues with components. The carb was more of a "do it while i'm there" kind of thing as it was temperamental in the past. As it sits now I am pleased at how it turned out. I just wanted to post a follow up in hopes it might help someone else down the road...…. Thanks for all the input.
Mon, Dec 2, 2019 11:32 PM
