d2 pony fuel shut off
ou812jk
Send a private message to ou812jk
are the valves available or what can I put in there to repack leaks from stem thanks
Fri, Nov 30, 2012 2:42 AM
Soapy
Send a private message to Soapy
I have two d-2's, and on both of them the valve stems leaked. I used teflon thread seal tape, pulled off about a 5ft. piece, doubled it several times, twisted it tightly, making a rope of sorts, opened the valve, backed off the jam nut, moved it away from the threads , and wrapped the teflon rope around the stem about three times, trimmed with a razor blade, and reinstalled the nut.
Fri, Nov 30, 2012 2:49 AM
you can usually find a "string' to pack them with that is sold at hardware stores for faucet stems. It's got graphite impregnated in it. The teflon works too. I usually have some pump packing "rope" around that I can unravel and get a string to wind around one. Just don't get too much under there so you can't get the nut started again.
Fri, Nov 30, 2012 2:53 AM
STEPHEN
Of course you can always open them up all the way to seal them off when running the engine. The valve is back seating, that is why you can't take them apart even if you loosen the nut
Fri, Nov 30, 2012 7:58 AM
