Reply to rmyram:
never had issues with floats maintaining a level whether they were the new solid ones, the old cork ones, or the hollow brass ones. set the float elvel as per the book and they have always been good.
If your having difficulty maintaining a level int he carburetor, i would suspect you have a fuel supply, or a needle and seat issue. How do you know your carb level is low? maybe the level is fine but you have a plugged passageway in the carb body that simulates a low float level situation.
[quote="rmyram"]never had issues with floats maintaining a level whether they were the new solid ones, the old cork ones, or the hollow brass ones. set the float elvel as per the book and they have always been good.
If your having difficulty maintaining a level int he carburetor, i would suspect you have a fuel supply, or a needle and seat issue. How do you know your carb level is low? maybe the level is fine but you have a plugged passageway in the carb body that simulates a low float level situation.[/quote]
Hi Roger,
seat, needle, and float are new. Blowing through the lines from the gas tank filler opening through into the bowl shows good flow as does letting gas run so I think I'm good there.
I've had the carb apart and checked all the passages including that one. I wondered about the float level because with the top off and the float out, there's about a 1/4" of fuel in the bowl. Obviously the float consumes some space in there but my other carb shows the fuel level higher. Also, if I fill the bowl up to about where the other one sits, it runs ok until it consumes that "extra" fuel and then stumbles again. The washer under the seat is "generously" proportioned so that might not be helping either. Anyhoo, I have a spare float so was going to experiment with it but wondered if anyone had already tried. Those new floats do vary a bit in dimensions.
