D2 pony crab body
D2 pony crab body
Showing 1 to 10 of 35 results
Riverina d4
Send a private message to Riverina d4
Decided today was the day to remove and service pony carb,clean cross passage etc and found the body to be broken. Very odd,will try to include pictures.
Any leads on a new body preferably down under would be appreciated.[attachment=51434]20181106_202302.jpg[/attachment]
Tue, Nov 6, 2018 4:34 PM
Riverina d4
Some more pictures
Top completely broken off.
Seems I've opened a can of worms. Previous owner must have some way damaged carb body.
Tue, Nov 6, 2018 5:03 PM
d2gary
Reply to Riverina d4:
Some more pictures
I've seen the body brazed back together in various places and work fine. Might be an option for you.
Tue, Nov 6, 2018 9:47 PM
STEPHEN
Reply to d2gary:
If the D2 is a J, where the intake elbow bolts to the firewall, check for binding or misalignment as that will break a new body. There was a mod a member sported a long time back to insert a hose in the elbow to stop the breaking.
Tue, Nov 6, 2018 10:01 PM
kal
Send a private message to kal
Reply to STEPHEN:
I have a D-4 with the pony motor and a 70 JD diesel with a pony motor and the carburetors sure look alike.Don't have them side by side to be sure but it might be an option.
k
Tue, Nov 6, 2018 10:26 PM
Riverina d4
Reply to STEPHEN:
The Machine is a 56 year 5U
May take the Brazing option as Gary Mentioned
Wed, Nov 7, 2018 3:34 AM
d2gary
Reply to STEPHEN:
Here's how the one on my j was done[attachment=51442]20181106_160158.jpg[/attachment]
Wed, Nov 7, 2018 7:07 AM
Riverina d4
Reply to d2gary:
After removing the two horizontal screws that hold the carb to the body what else holds the two items together?
Have done a quick search and read some old threads but can't get my head around it.
Thanks in advance
Wed, Nov 7, 2018 9:02 PM
hfdzl
Thanks in advance
IIRC there is a thin walled brass tube/jet that goes into the cast iron body from the float chamber. . Be very careful as it can be broken easily. The whole carb comes off with 2 bolts one of which is under the float bowl. The bolt under the bowl is difficult. The carb has to be lifted as you take the bolt out. Take the entire unit off and soak in lacquer thinner.
Good luck
Wed, Nov 7, 2018 9:35 PM
d2gary
Thanks in advance
There's a long brass jet that runs through the cast body into the bowl. You have to pull it past the jet before you can pull it up.
old-iron-habit
Reply to kal:
[QUOTE=kal;214995]I have a D-4 with the pony motor and a 70 JD diesel with a pony motor and the carburetors sure look alike.Don't have them side by side to be sure but it might be an option.[/QUOTE
If I remember right they are basically the same carb. I think the throttle linkage is opposite on the JD pony motors. The carb kits have many interchangeable parts.
Thu, Nov 8, 2018 2:08 AM
