D2 pony compression
D2 pony compression
Todd
Send a private message to Todd
I picked up an old D2 last summer. It's about a 1950 model. The seller was able to get the pony going, but it was "finicky". There was rust in the gas tank, and the carb controls had to be "just right" to get it started and keep running. When I got it home, I got the gas tank cleaned and lined, and rebuilt the carb (new float, needle and seat, gaskets, etc.). The weather then turned sour. With the weather warming, I'd like to get back at it. The pony compression is between 60 and 65 pounds (both sides). Is that sufficient, or should I be thinking about trying to "refresh" it (and is that very difficult?). I understand parts can be hard to come by.
Also, the track adjustment nuts are pretty rusty - how difficult might it be to free them up?
Sat, Apr 10, 2010 7:16 AM
Painter
Send a private message to Painter
I don't know about the compression, but on the track adjusters, I soaked mine with penetrating oil, resoaking them several times over the last 6 months, then loosened everything up, and used an air chisel to slightly spread the slits in the adjuster nuts. then hit on the edge of the nut with the air chisel til they turned a little, went to a big crescent wrench to finish adjusting. About 15 minutes per side. Mine is a 1944 d25j
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
Sat, Apr 10, 2010 7:28 AM
SpragueM
Reply to Painter:
I have several and all are in the 55-75 range. All start and run fine ,so I do not believe it should cause you any trouble. I have never seen the new or newly rebuilt figures.
Matt
Sun, Apr 11, 2010 12:31 AM
Rd6 plower
Send a private message to Rd6 plower
Reply to SpragueM:
Matt
There's nothing to worry about but if you did put new rings you'd have to pull the pony completely off so you can pull the top part of the pony which is were the carb and mag and manifolds go then pull the valve springs and lifters then pull the cam then you can get at the connecting rods so in other words complete tear down! 😄
Sun, Apr 11, 2010 1:19 AM
