D2 pony
1canoeman1
Send a private message to 1canoeman1
How tight to tighten the end plate bolts in back of the fly wheel? I was told they can be to tight. Thanks in advance. Also should I put any cement on the new gasket?
Thu, Oct 15, 2015 12:30 AM
Mike Meyer
Thank you received: 6
From memory they are 1/4" or 5/16" those bolts, torque spec for 1/4" is 8-11 foot pounds, 5/16" is 12-16 foot pounds, in theory new Cat gaskets do not need any gasket goo, if you want to be 110% certain then put some on.
Regards
Mike
Thu, Oct 15, 2015 2:03 AM
1canoeman1
Reply to Mike Meyer:
Regards
Mike
Thanks a lot Mike, I now hope to get this pony running soon.
Sun, Oct 18, 2015 12:12 AM
