D2 Piston liners
D2 Piston liners
C.J._archive1
Send a private message to C.J._archive1
Can someone tell me if the D2 liners 8B438 are interchangeable with 4B6431. Thanks
Tue, Dec 25, 2018 8:11 PM
josh
Thank you received: 14
Hi C.J.
I do not see any cross, or any reference to 4B6431,where did you get that number?
Other numbers for 8B0438 are 2A5613, 5F6722, 3H6012.
Fri, Dec 28, 2018 8:45 AM
C.J._archive1
Reply to josh:
Hi C.J.
Josh 4B4631 is liners for the gas engine R2 thought they might interchange with the D2 liners I believe the engine blocks are the same and the crankshaft is the same also. Thanks
Fri, Dec 28, 2018 9:40 AM
josh
Reply to C.J._archive1:
The correct number is 4b6341, there is no cross shown for the liners, and the blocks also show no cross between the J series R2 and the J series D2.
Crankshaft does cross.
Fri, Dec 28, 2018 10:51 AM
