Reply to Mike Meyer:
I've been recently quoted around $US800 per side to fit new pins and bushes to my D2 4U here in Australia by two different shops 2,000 miles apart, I think they are Berco parts. New chain is available too for about $US900 per side but you need to drill slightly larger holes in your plates for the grouser bolts, I think it's about 1/16th" larger. So yes, the parts are available. The problem sounds like when you need bottom rollers, they are harder to find in good shape, but the bottom roller seals are available for about $US25 a piece and you can fabricate new bronze bushes fairly easily, well, a good machine shop will, it's all just about time and money as you know. I've just finished building up my bottom rollers with the arc welder, that took awhile, now I'm ready to tackle the bushes and seals, my tractor had no seals left at all.
regards
Mike
[quote="Mike Meyer"]I've been recently quoted around $US800 per side to fit new pins and bushes to my D2 4U here in Australia by two different shops 2,000 miles apart, I think they are Berco parts. New chain is available too for about $US900 per side but you need to drill slightly larger holes in your plates for the grouser bolts, I think it's about 1/16th" larger. So yes, the parts are available. The problem sounds like when you need bottom rollers, they are harder to find in good shape, but the bottom roller seals are available for about $US25 a piece and you can fabricate new bronze bushes fairly easily, well, a good machine shop will, it's all just about time and money as you know. I've just finished building up my bottom rollers with the arc welder, that took awhile, now I'm ready to tackle the bushes and seals, my tractor had no seals left at all.
regards
Mike[/quote]
Mike--FPSmith has new Berco rollers for a D2--they are double flange and $225 each-I bought 2 of them
Dan
