d2 pilot bearing
d2 pilot bearing
sbybee
Send a private message to sbybee
I checked the archives and found out how to double check the flywheel timing. I guessed right. Now on to the pilot bearing, the book says to use oil, would grease be better. I should check the archives on that I guess. After a transmission main shaft seal gets here I should be ready to install engine. thanx
d2, 2n, 8n, 4000, cub cadet 169, massey compact, home made tractor, and more
Exact center of California
Tue, Apr 17, 2012 8:02 AM
Jack
The old J series D2 used transmission oil in the big cup on the top plate, but had a grease fitting on the back edge of the flywheel for greasing the pilot bearing. As far as I know D2's all used a greased straight-roller pilot bearing in the flywheel. What series is your D2?
Tue, Apr 17, 2012 11:34 AM
sbybee
Reply to Jack:
It is a 1940 3J.
Tue, Apr 17, 2012 9:02 PM
Jack
Reply to sbybee:
It is a 1940 3J.
3J and 5J used oil--90W--in the cup on top. Be sure it has a wick in the bottom so it will drain into the throwout bearing during the course of the day. Grease the pilot bearing about as often as you change oil. Roll the engine over until you find the fitting at the top under the plate. Then you will probably need a gun with a hose to get onto the fitting. Give it a couple shots. There's no place to see if it is coming out, and it doesn't take much anyway.
The J series was a pretty good old Cat. I have been running my 5J since about 1969 and think the world of it.
Wed, Apr 18, 2012 7:47 AM
Price Tractor Pull
Price Tractor Pull
