D2 parts
deannis
Send a private message to deannis
Anybody know of A source for D2 parts? Thanks
Fri, May 13, 2011 12:23 PM
gemdozer
I am still have some used D2 parts
Fri, May 13, 2011 5:20 PM
Reply to gemdozer:
That is an easier question to answer if you post where you are located? Tractor parts get heavy or bulky quick, hence expensive to ship. It helps to know where you are to determine what person or company to refer you too. Plus being more descriptive on what parts you need exactly for what vintage of D2 U or J series, early or late serial number?
GemDozer has good stuff and is GREAT to deal with!
Jeff
Fri, May 13, 2011 5:50 PM
ol Grump
Reply to drujinin:
Jeff
If you're in the western Half of the US, Phillips Tractor in Gaston OR (503-662-3929), NW Tractor in Boring OR (503-658-5545) or General Gear in Boise ID (208-342-8911) have all been good to deal with. If they don't have what you're looking for, they'll usually refer you to someone else who might.
Fri, May 13, 2011 8:02 PM
bernie
Reply to ol Grump:
Good suggestions by O'l Grump. I've dealt with a couple of the fellows he mentions, and Hector, (Gemdozer), is exceptional to deal with.
Good luck and if you have specific parts you might go ahead and list what your needs are.
Fri, May 13, 2011 8:05 PM
B4D2
Reply to bernie:
At the top of the discussion section is a "sticky" that has several suggestions for parts. It all depends on what you are looking for. I think a lot of us have some spare parts laying about. Let us know what you need.
Fri, May 13, 2011 8:18 PM
Reply to B4D2:
I forgot to mention the "sticky"!! We all use it but never think to pass it on to the new members! It and a telephone will track down anything(if still available) quickly.
Sat, May 14, 2011 12:56 AM
deannis
Reply to drujinin:
Hi all, I have a D2 ser#3J1801, it has what i believe to be the 6b463 oil filter group. In the bottom is a cleanable brass element, and disposable paper element in the top. what I need is the spring special washer,retainer and gasket for holding top element in place. My upper housing does not contain any of those parts so the element flops around and does nothing. Part no. are 6b2319-retainer,6b3015-ring,6b977-washer,5b8912-spring. Thanks Dean Seattle Wa, 425-766-1507. Also looking for air cleaner- pre cleaner assembly.
Sun, May 15, 2011 4:58 AM
deannis
Reply to deannis:
Found the for sale, wanted page. Thanks
Sun, May 15, 2011 10:44 PM
