D2 oil filter
D2 oil filter
Showing 1 to 10 of 15 results
Jason 10/D4
Hey guys picked up a nice barn fresh D2 in my own back door and was wondering if you guys had a oil filter # for napa, carquest or a cat # don't have a book on it yet its a 3j model and was wondering if a 2t d4 filter is the same might have a spare cat one instock. Thanks,Jason
Sat, Feb 7, 2015 6:19 AM
cojhl2
Just go to NAPA, they know the filter. One thing though you need to know if it is the original bypass or has it been converted to fullflow. The way to tell is the tightdown nut. It is a slotted nut or a t-handle. If a slotted nut it is a fullflow convert.
Sat, Feb 7, 2015 6:43 AM
Jason 10/D4
Reply to cojhl2:
Thanks for the reply I have 2 1r-0659 filters in stock will they work on a 2 or no?
Sat, Feb 7, 2015 8:22 AM
Reply to Jason 10/D4:
It's not that easy. There are five possible filter arrangements for the 3J.
Need to go by s/n.
Sat, Feb 7, 2015 10:37 AM
cojhl2
Need to go by s/n.
Ooops, sorry for the incorrect info.
Sat, Feb 7, 2015 12:05 PM
Jason 10/D4
Reply to cojhl2:
It is a 3j 5480 sp s/n and it has the T handle on the hold down assembly Thanks,Jason
Sat, Feb 7, 2015 8:20 PM
my 1939 5J parts book shows element assembly 6B1851 or element 6B907 if that helps--this is 2 years older than your 3J
Sat, Feb 7, 2015 9:34 PM
Reply to dpendzic:
3J5480 originally used a by-pass filter (T-handle). Element 6B1851 is a screen and 6B907 is a replaceable element RPB Cat #1S9150 = Wix 51165
It is possible to convert 3J3445-up to full flow with the correct parts.
Sat, Feb 7, 2015 11:08 PM
Jason 10/D4
So I guess I will have to pull it apart to see what is inside the housing I think my 2t d4 has the brass screen in it. Thanks for your help, Jason
Sun, Feb 8, 2015 1:20 AM
Yes, in this case it is the same as the 2T.
Sun, Feb 8, 2015 1:30 AM
OM--if it was converted to a full flow would it still have the t handle on it??
thanks
Sun, Feb 8, 2015 3:27 AM
