D2 Oil Drain Plug Gasket
Showing 1 to 6 of 6 results
Cat Yellow1
Send a private message to Cat Yellow1
Thank you received: 6
My D2 (4U1826) is leaking oil at the drain plug of the diesel engine, but I'm unable to find a part number for the gasket in the parts book.  Does anyone have a part number?  I see the plug in the bellhousing shows 2, but not sure if it is the same plug as the engine base use.  Could someone confirm?  Red arrow on the graphic.  Thanks.
 [attachment=68869]D24U Engine Block.jpg[/attachment]
Tue, Sep 6, 2022 5:02 PM
PhilC
I would say the part number is 0L-1124 as you suspected. As far as I know all drain plugs are the same except the ones on the steering clutches.
Tue, Sep 6, 2022 6:38 PM
gemdozer
Thank you received: 25
The plug is l-827 and gasket l -1124 same from cluh housing
Tue, Sep 6, 2022 6:42 PM
Reply to gemdozer:
0L-1124, put separated side towards plug.
Tue, Sep 6, 2022 8:15 PM
side-seat
If it's just the drain plug all you need is a new copper washer that fits the drain plug.
Tue, Sep 6, 2022 8:24 PM
Reply to side-seat:
Same as the bellhousing uses.
Wed, Sep 7, 2022 12:48 AM
Cat Yellow1
Thanks All. That's what I suspected but thought I'd check here before I ordered.
Wed, Sep 7, 2022 5:54 AM
