D2 Oil Cooler Lines Leaking
n7gxz
Send a private message to n7gxz
I've had one of the oil cooler lines leaking for the past few years, pin hole or two. Since they are no longer available so here is my solution to fixing the leak. I used some 12L14 1-1/4" hex stock to make the fitting adaptors. Then installed 1/2"ORS to 1/2"JIC into the adaptors that I machined. Hose is 300PSI rated.
Kevin
[attachment=15135]DSCN1735.JPG[/attachment][attachment=15136]DSCN1736.JPG[/attachment][attachment=15137]DSCN1737.JPG[/attachment][attachment=15138]DSCN1738.JPG[/attachment]
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Thu, Oct 25, 2012 10:42 PM
BullDozerBob
Send a private message to BullDozerBob
n7gxz,
Nice work-amazing what a guy can do with skill and good tools.
By the way , thanks for all the rain-looks like another ten days coming our way!
BullDozerBob
Spokane Wa.
Fri, Oct 26, 2012 12:14 AM
n7gxz
Reply to BullDozerBob:
n7gxz,
BullDozerBob
Spokane Wa.
I have a 1954 Atlas/Craftsman 12x48 lathe that I used to do the machining. I can post the drawings if anyone is interested.
Glad to send the rain you way. After about 80 days of dry on the west side the start of the rains was a nice change, things were getting veryyyyy dry and very high fire danger.
Kevin
Fri, Oct 26, 2012 1:12 AM
kracked1
Reply to n7gxz:
Kevin
Looks great! Very clean install.
Fri, Oct 26, 2012 1:57 AM
Mike Meyer
Thank you received: 6
Reply to kracked1:
Well done, good quality job there.
regards
Mike
Fri, Oct 26, 2012 3:28 AM
zootownjeepguy
Reply to n7gxz:
Kevin
Those old Atlas lathes sure do get around. They were built right here in Kalamazoo. 👍👍
Nice job on the New Oil Cooler lines!👍
Rich Salvaggio
D2 5U9917
Fri, Oct 26, 2012 7:19 AM
| Kingaroy, Queensland
