D2 Oil cooler leaking
Showing 1 to 9 of 9 results
Tugger
Send a private message to Tugger
I was wondering what the best solution would be to replace the oil cooler on my D2.The rad shop said mine was not repairable,they didn't think they could open it up to pinch the failed tubes off.It appears to be leaking right near the bottom,so the other tubes maybe close to going as well.Are there reasonably priced reproductions available?If a used one was found what kind pressure should it stand as a test?
Wed, May 3, 2017 10:04 PM
ag-mike
no new replacements i know of. i test them at 40psi and guarantee it not to leak for 40 seconds. prob is one never knows when its gonna let go because of rust. by pass ur cooler.
Wed, May 3, 2017 10:20 PM
old-iron-habit
Reply to ag-mike:
You can bypass it with no issues. Cat got rid of them in later years as not needed.
Thu, May 4, 2017 7:30 AM
Tugger
Reply to old-iron-habit:
Thanks guys. I think ill do the bypass for now and hold out for another cooler,i have a line on one if it tests out.It would be nice to keep everything as close to original as possible if I can.
Once again
thankyou
Tugger
Thu, May 4, 2017 10:26 AM
Reply to Tugger:
Once again
thankyou
Tugger
If you use the SEARCH function in the upper right of your screen, you'll find at least a 100 threads on "leaking oil coolers".
Which may convince you to not worry about having a functioning oil cooler.
Thu, May 4, 2017 6:28 PM
seyser
Thank you received: 60
Reply to Tugger:
Once again
thankyou
Tugger
[quote="Tugger"]Thanks guys. I think ill do the bypass for now and hold out for another cooler,i have a line on one if it tests out.It would be nice to keep everything as close to original as possible if I can.
Once again
thankyou
Tugger[/quote]
Nothing wrong with that. I much prefer original if at all possible.
Thu, May 4, 2017 8:46 PM
CarlsCAT
Send a private message to CarlsCAT
Reply to seyser:
Once again
thankyou
Tugger[/quote]
I suppose in some areas...bypassing the oil cooler works...But, there was a reason to have an oil cooler...and, in the hotter climates, it is probably necessary...
Most diesel engines, including automobiles, have oil coolers...That being said, I replaced the oil cooler on my CAT 212 with a new aluminum one manufactured by the Radiator Shop in Oregon...It fit just fine...and works just fine...You can put your hand on the inlet and outlet pipes to the cooler and can feel the difference...
Removing and replacing the old iron oil cooler is not a difficult task...Would I replace the oil cooler on another of my CAT 212's or D2 with a new aluminum one ?...You bet I would... I would not waste my time bypassing the oil cooler...
Take a look at my thread on replacing the oil cooler on my CAT 212 grader...
Respy, CarlsCat...
Thu, May 4, 2017 10:55 PM
ronm
Reply to CarlsCAT:
Respy, CarlsCat...
I didn't like the idea of just removing the bypass valve or jumping the lines together beside the engine so I came up with this. ..1/2" hydraulic tubing & built the manifold blocks. This Cat will never get worked hard enough to need a real oil cooler.
Yeah, I know-should have painted it black...
Thu, May 4, 2017 11:31 PM
Reply to ronm:
what do you think the operating maximum temp of the oil should be? Same as the coolant temperature?
Thu, May 4, 2017 11:58 PM
ag-mike
Reply to seyser:
Once again
thankyou
Tugger[/quote]
it was a factory bulletin stating that the cooler on the tractor wasn't necessary trying to get operating temp up. thats original isn't it? if u want original looks keep and plug lines connected to the empty cooler. AFTER REMOVING BYPASS PISTON. good luck with ur project.
Fri, May 5, 2017 3:13 AM
