d2 oil change
d2 oil change
68dually
Send a private message to 68dually
I just aquired a D2 and would like to know what you guys run for oil in the engine and the pony. I usually run rotella 15/40 in everything that I have and would like to keep that up if I could. The manual calls for sae20 or sae10 depending on the weather.
Thanks, Randy
Fri, Oct 28, 2022 10:38 PM
Pennzoil 30W or 10W-30 for the starting engine and older type diesel engine oil 30W or 15W-40 for the diesel.
Fri, Oct 28, 2022 11:26 PM
| Kingaroy, Queensland
