D2 Oil capacity
D2 Oil capacity
Showing 1 to 10 of 11 results
Pioneer1930
Send a private message to Pioneer1930
Hello, I know I'm being impatient here but I'm chomping at the bit to mess around with my new D2. I ordered my books for it this week but I really want to change the oil this weekend and I don't know the oil capacity of the engine. Its a 5J from 1940. I have the filter. I'm sure someone could answer this off the top of their head. I searched and couldn't find it in the archives. Thanks for any replies!
Fri, Jan 29, 2010 10:47 PM
SJ
Send a private message to SJ
I don,t have a book on one that early but the D311 later engine in a 933 11A loader shows 4 gal.(16 qts.) for the crankcase so yours probably is close to that.You have to check it with the engine running and idling as the dip stick shows the full mark for it idling (running).
Sat, Jan 30, 2010 12:55 AM
Reply to SJ:
Are you sure you have the correct filter? The J series had a bypass oil filtration system with a 2 piece filter. Some of the earlier ones were converted to a full flow system like the later ones.
Sat, Jan 30, 2010 1:28 AM
Pioneer1930
Reply to drujinin:
I'm pretty sure its the one. I got it at Napa. I haven't opened the cannister it goes into but it looks kosher. (I kept the reciept!) Thanks for the heads up though.
Sat, Jan 30, 2010 1:39 AM
SJ
Reply to Pioneer1930:
If it is the by-pass in it yet then the outer filter inside it is a fine mesh metal screen and the throw away paper filter is inside it.If it has been changed over to the full flow filter then there will just be one big throw away inside the base.Also the by-pass had a tee handle on the outside of the top cover and if it has been changed over it has a hex nut with a groove cut across the hex nut.
Sat, Jan 30, 2010 2:11 AM
Reply to SJ:
Capacities:
Cooling system, in U.S. standard gal............................................... .......................7 3/4
Lubricating system:
Crankcase, in quarts............................................ ..............................................13
Transmission case in quarts............................................ .......................................8
Final drive case (each), in quarts............................................ .................................4
Fuel Tank, in U.S. standard gallons........................................... ..............................20
..........................................50" gauge.................................. 40" gauge
Over-all Width.......................5' -5 3/4"......................................4' -7 3/4"
Weight, shipping (approx)......6,650 lbs....................................6.520 lbs.
Sat, Jan 30, 2010 2:56 AM
CarlsCAT
Send a private message to CarlsCAT
Reply to SJ:
You might consider doing a kerosene flush of the engine before just changing the oil...It would help clean out all the sludge that may have built up in the engine...particularly in the bottom of the pan...Do you have any idea as to how long it's been since the engine oil has been changed ?...
The D311 engine oil capacity for my CAT 212 Grader...
is 14 quarts, or 3 3/4 gallons...the same as my D2 3J...
Sat, Jan 30, 2010 2:59 AM
Pioneer1930
Reply to CarlsCAT:
I would have to say it has been probably 5 plus years. From what the guy I bought it from said. I know the guy I bought it from and he's pretty reliable. After unsticking the float I ran the pony last weekend. It runs strong, hard to get started though. I think most of that was me kinda learning the sweet spot on the controls. I wanted to change the oil in the main engine before I start it to prevent any crap and sludge from getting pumped all over the engine. When you flushing this out are you just pouring kerosene or diesel fuel into the filler and draining accordingly? Also I have the cannister with the tee handle so I hope my filter fits?! I'll find out this weekend.
Sat, Jan 30, 2010 5:03 AM
CarlsCAT
Drain the old oil from the engine...Fill it up with kerosene...
With the engine on start, or decompression, turn the engine over with the pony motor running...turn the engine over for a time to circulate the kerosene through out the engine...so the kerosene will dissolve the sludge...Let the kerosene set in the pan for awhile to allow it to dissolve the sludge in the pan...Then drain the kerosene out...You might remove the inspection panels on the sides of the pan to see how much sludge is in the bottom of the pan...and if the oil pick-up bell is clogged...Have you ran the engine yet ? ...What's the oil pressure look like ? ...Take your time with the machine...Try not to get toooo excited and overlook some maintenance that needs to be done...Good Luck...
Sat, Jan 30, 2010 9:56 AM
Kelly
Reply to CarlsCAT:
Try this.
http://www.acmoc.org/bb/showthread.php?8316-D2-Oil-capacity
Kelly
Sat, Aug 18, 2012 4:38 AM
maniklu21
Send a private message to maniklu21
Hi, friends i have a caterpillar d2 with d3400 engine.
Can you please tell me about the oil pressure?
Maniklu 21
Sat, Jan 31, 2015 7:36 PM
