D2 now home.
D2 now home.
Showing 1 to 10 of 31 results
DCurrin
Send a private message to DCurrin
Hey gang.
IT's HERE!
D2 (duh) 5U7873
Year ??? Thanks
I need someone to tell me the type/manufacturer of the blade system.
Many things to do.
biggest thing I need is a grill radiator guard assy.
I have about everything that seems to be missing. I Think.
Thanks in advance for all and any help.
I have all the manuals and an operators manual.
I will try to keep them to intelligent questions.
Cheers
Dudley
😊 😊 D2 😊 😊
Stuck Left Clutch, Dang
Tue, Dec 4, 2007 5:38 AM
compressor
Send a private message to compressor
The blade you have is a cat 2A .
I think that you will find a 1 infront of the 7 on the ser # later tractor. 1956
! would kill for that thing.(later style).
good luck compressor
Tue, Dec 4, 2007 6:34 AM
Reply to compressor:
I show 5U7873 as 1951.
That is the early style Cat angle blade.
Congratulations😄 😄
Tue, Dec 4, 2007 6:59 AM
compressor
Congratulations😄 😄
Hurry, run out and comfirm that ser # I will bet it's 17873. you lucky dog you.It's even got a winch.It probably runs great, steers like new,right I don't even want to know how much you gave for it. I have been looking for one of those for the last 3 year's. So when you get sick of it, let me know.
BEST OF LUCK AND NO MATTER WHAT PEOPLE TELL YOU, YOU HAVE FOUND A REAL JEWEL CONGRADULATIONS.AND AS FOR ME, I'LL JUST KEEP LOOKING.
COMPRESSOR
Tue, Dec 4, 2007 7:13 AM
DCurrin
COMPRESSOR
Comp, et al,
thanks for the info,
Too dark😠 to see numbers behind the winch😄
I have some wrenching to do yet.
install pony motor, dash and misc,
maybe the electric starter PO bought,
Bleed fuel system, PO ran it out and could not reprime it.
PO lost interest in project.
I hope to at least have it running by the weekend.
Supposedly one stuck steering clutch, but they are supposed to be new, hopefully the brake bands were done then also....
Rolls well, was easy to load.
Weighs 10,300 a bit from the 7,000 in the book,
Hauled it 150 miles to home on a new to me trailer with my 96 GMC K3500.
Price well I am happy and so was the seller.
we shall see in the long run,
Hey PasoChris,
My project has begun, Not near the mountain you have climbed. Keep us posted on your progress.
Cheers to all
Dudley😊 😊 😄
😊 😊 D2 😊 😊
Tue, Dec 4, 2007 10:00 AM
pasochris
Send a private message to pasochris
Reply to DCurrin:
Comp, et al,
Hey PasoChris,
Cheers to all
Dudley😊 😊 😄
DCurrin,
Congrats, looks like you got yourself a real nice tractor. I'm sure you'll have it up and running in no time. With a little luck the stuck clutch will break loose as soon as you put a little load on it.
Hope she fires up for you, and take some more pics when it does.
Chris Clarke
Wed, Dec 5, 2007 9:02 AM
DCurrin
Reply to pasochris:
DCurrin,
Better pictures.
I am trying to get them posted to picture trail.
For better viewing.
enjoy for now
All I got to do today on the D2 was take pictures. Other chores.
Cheers
Dudley
Chris,
Thanks for the note.
Compressor,
No chance for 17873 Wrong transmission, four rollers, wrong dash,
oh well you did not miss anything here.
😊 😊 D2 😊 😊
Wed, Dec 5, 2007 9:26 AM
B4D2
Reply to DCurrin:
Better pictures.
For better viewing.
enjoy for now
Cheers
Dudley
Chris,
Compressor,
Hmmm, it does look like some parts off a late model D2. Compressor spotted some. It looks like the larger seat fuel tank and the flat plate fenders are dead give aways to a late model, but the roller spacing looks close, like that of an earlier U series D2. Regardless, a nice straight looking machine with all the goodies. Have fun.
Wed, Dec 5, 2007 9:51 PM
compressor
Reply to B4D2:
B4D2
You spotted the seat and fenders also.Could be a take two and make one unit.
Question you will know.
The differnce between late model and early model 2A blades assm. One is longer or what.I know you sold one here awhile back.
Thu, Dec 6, 2007 6:42 AM
B4D2
B4D2
Comp, I recall the issue was raised, but the blade assembly I sold was off a late model D2, thus if it is longer, it would have accomodated either early or late variants. The track frame PN's are way different from early to mid to late model U series. I recall somebody offering that the blade assembly is the same length, just the blade mount is moved forward on the longer track frame of the later D2. When I look at the diagrams drawn in the parts manuals, the bolt holes appear to be further forward as suggested. Sorry I cannot be of more assistance to you.
Thu, Dec 6, 2007 8:49 AM
DCurrin
Reply to B4D2:
Today I got to play with the D2.😄
Found fuel tank almost full.😄 $50.00
Found shut off below tank to be closed. opened it and let things set.
no leaks to transfer pump. 😊
opened bleeder at top of fuel filter a bit later fuel comes out. 😊
Opened bleeder for lower section of fuel filter, front bleeder.
After a few minutes Fuel. 😄
Now the bleeder at the injection pumps.
After a few more minutes more fuel. 😄
Ok that side taken care of.
Check fluids, all ok at this point. Will be changed shortly.
Now put electric starter together that came with crawler.
Clearanced nose cone on starter drive.
figured out where to clock starter. pulled it all back out.
bolted starter to block. hooked up a battery.
clunk clunk 😕 😠
pulled it back out and ran on ground ok.
Put back in.
Clunk Clunk 😠 😠 😠 😠
Pull it back out. turns free.
pull nose cone. check starter gear against remains of old starter gear.
It is smaller and has 12 teeth. so according to OM page.
Should be ok.
Put starter back together.
check battery 8D voltage 12.2 😮 😠
put battery on charge
end of day
Darn, so close yet so far.
Cheers
Dudley
😊 😊 D2 😊 😊
Thu, Dec 6, 2007 9:48 AM
